Topic: Flex-A-Lite electric fan (Read 5617 times) previous topic - next topic
I like my Taurus fan, I feel confident that my engine is nice and cool.  Really does need a decent fan controller though, I went for a cheap one and it melted the wires ;)
Quote from: Sick88Tbird;124232
I do think flex-a-lite's s-curved fan blades are more efficient than OEMs.
Why.
Quote from: JeremyB;124199
Actually, the early MKVIII fans flow better than the later fans. I can't remember the year they changed the blades though. Later MKVIII fans shared blades with the MN12 fans.
IIRC, the Mark VIII fans are in no way identical to the MN12 e-fans.  The MN12 fan is a two speed fan, while the MarkVIII is a computer controlled, variable speed fan.  The Mark VIII blades will not bolt up to the MN12 fan motor.
Unless you do some fancy stuff, when you hook up a Mark VIII fan with a regular fan controller, the fan is no longer variable speed, and is all on all the time (at least when the switch turns it on).  That fan will suck small children, Crystal, and Weasle up against your grill.
And according to folks at TCCoA, the 98 fan is the best one.
-John Fordham
1993 Cougar XR7 302 HO AOD
245,000 miles and still running strong
2005 F-150 FX4 SuperCab 5.4L
Sounds like you also need a small nuclear reactor to run the thing...
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Quote from: Red_LX;124314
Well I wouldn't recomend the stock alternator that's for sure...:tg:
what's required as far as input from the computer to run the mark fan? mark puter, or will the t-bird/cougar puter work?
Nothing from the computer. You need to make or buy your own controller, variable speed or not.
1988 Thunderbird Sport
Quote from: jncocowboyx;124354
You can run a Mark computer and convert to the Mark's 4.6 DOHC and 4R70W trans (which would be kinda sweet), or run a stand alone fan control, which is what the 5.0 MN12 guys do.
-John Fordham
Quote from: Johnny Cougar;124307
The internets say otherwise. The internets also agree with you. :hick:
I spent a while searching for Mark VIII fan posts, and ended up with nothing but contradictory information.
A few posts say the older (93-96) fan outflowed the later fans. (1)(2)(3)
Other posts said the later fans outflowed the earlier fans, or that they all flowed the same (1)(2)
Some posts said the MKVIII and MN12 fans were the exact same except for the motor. Others disagreed. (1)(2)(3)
Heck, I found a post or two saying the 93-96 fans were 2-speed, but the later fans were 1-speed. (1)
I think the '98 fan is 'best' is because it is the cheapest when bought new, not that it is superior to the other fans performance-wise.
From the thread I posted above:
The truth about '94-95 (maybe up to '97) MN12 E-fan and the '93-'96 M8 fan..
Since i have both, right next to each toher... Just looking at them, they do look the same.. but the connections are the same plugs, but the M8 is only ONE speed, where as the MN12 one is TWO speed... The M8 fan out pulls the MN12 on high..
The shroud IS the same..
The fans blades ARE the same..
The motors are different; F3LU-8K621-AA for the M8, F4SH-8K621-AA for the MN12
Oh and the motor and blades are MADE IN CANADA !!
Also i Believe the M8 Fan is orginally Bi-wired on the postive side.. i've hooked it up that way for testing, and the 12Ga wiring i was using as a test never got hot, nor the connectors... Also it's how it's wired in a M8..
Quote from: JeremyB;124239
Why.
Because from what I've seen, the s-curved blades(typically) flow significantly more with less amperage draw.
Quote from: Sick88Tbird;124509
That might be true compared to 'flat' blades, but not the blade design that the MKVIII uses.
Quote from: JeremyB;124510
Yes, I'm speaking in comparison to flat or straight blades, I'm not too familiar with the MKVIII design so I can't speak for that.
Quote from: Sick88Tbird;124609
The MKVIII fan has a blade that varies the pitch angle wrt radius to give equal flow velocity wrt radius.
The old saying remains true, "you learn something new everyday".  Thanks for the enlightenment.  :D
