motor mounts January 11, 2007, 03:03:40 PM does anyone know a good place to jack up the motor? i have never done this b4 i have a set of directions but it says to read the servicec manual which i no longer have Quote Selected
motor mounts Reply #1 – January 11, 2007, 03:10:28 PM whenever I have to lift the engine in my 79 cougar (5.0) I undo the mounts and jack up on the trans bell housing. Quote Selected
motor mounts Reply #2 – January 11, 2007, 03:35:41 PM I usually put a big flat piece of wood on my floor jack and lift under the oil pan.Never had any problems with that in all my years. Quote Selected
motor mounts Reply #3 – January 11, 2007, 08:50:35 PM What's up!:grinno: I'm new to the board. I agree with the other guys. I've used a bottle jack under the balancer and also unbolted the nuts off the trans mount and the bolts on the fan shroud. Sometimes the mounts are a tight fit and lifting the motor helped some;) If you don't mind me asking where did you get your mounts from? The parts guy asked me if my vehicle was Canadian because that's all he showed for a V-8:rollin: He sold me 2 Doan 2661SR. I hope they work, since the Ford guy told me they were discontined. If my memorey serves me I believe there were 2 separate Ford #'s though. I just thought you might have some part numbers handy.Thank muchMike Quote Selected
motor mounts Reply #4 – January 12, 2007, 07:52:01 AM Quote from: vinnietbird;123191I usually put a big flat piece of wood on my floor jack and lift under the oil pan.Never had any problems with that in all my years.+1 Quote Selected
