Topic: Bypass the switch (Read 5430 times) previous topic - next topic
Bypass the switch
i want to bypass the dimmer switch on my headlamp switch so i can have dash lights until i can get a new switch is it possible.  I just want them on full blast.
Quote from: Krazy_Kling;210178
Honda owners are like rabbits......they hide under your shed during the winter and then 30 of them come popping out around spring.
ASE certified parts specialist.
1988 Mercury Cougar Blue Max edition. SOLD
2004 Impala
My Cardomain http://www.cardomain.com/ride/799588
Bypass the switch
87evtm shows a diagram in the pic below.
The  pic is pointing out information you will need to jumper past the dimmer.  If i had to do what you are doing, i would install a jumper between wire colors
BROWN
Light brown/ RED
The 87evtm does not show one single schematic wtih all wires connecting to the main light switch so each feature is broken down into different sections. i can provide a schematic if you need but the below should be good nuff.
if the jumper does not work, then your prob isnt the dimmer. Its either a fuse or cluster illumnation relay and so on , so forth.
Bypass the switch
hmmm,, wait a minute,, something does not add up ,,leme look at some other diagrams.
ok,, did a stare and compare on different diagrams.  A man can go crazy thumbing through a light switch diagram on most any vehicle.  It appears to me that what you are doing is looping back a fused circuit to a fused cicuit that is supplied by a hot at all times fused circuit that feeds the main light switch.,,,,Make sense?  lol.
Annnnnyyyyyywayyyyy,,,,,,looks ok to me if you jumper the wires i said.  I am 98% sure its ok,,lol.
I would still start here and jumper these two wires without a worry,, i would have no choice based on what i have researched.
Anyone disagree?
Bypass the switch
Thanks for that i will attempt it today and we'll see what happens.
2004 Impala
Bypass the switch
I've done this before. On my mustang and on a grand am.... now what the hell did I do???
Scott
Bypass the switch
It didnt work I used the diagram to jump the wires to the correct terminals and nothing it still works exactly as it used to, the dash works with the headlights off, but the second you flick the switch the dash goes black.  This wiring is a nightmare.  Arrrgh i'm starting to get frustrated with this car.
2004 Impala
Bypass the switch
Could be the cluster illumination relay as well...
Bypass the switch
ooooooooohhhhhhhhhhh
dash goes dead when you turn on the darn headlights,, why didnt you say so off the top.\
does the dimmer work with no headlamps??????
My first and only guess would be you have more than enough bulbs blown and that causes clusters to go blank when the headlights are turned on.
This is what happened to me a few years ago, i had to replace several bulbs.  I dont know why but when you have several or a few bulbs blown, you get this symptom.  I think it has to do with loading of the IVR ect ,,,dono, i just know that i replaced bulbs and stuff started working again.
everyone agree????????
Bypass the switch
Do we mean the dimmer SWITCH for the headlights, or the dimmer WHEEL for the gauges? When the lights are off, the radio, clock  and speedo get full power. When the lights are turned on, the other dash lights (gauges, heater panel, etc.) are brought into the circuit, and the "cluster illumination relay" switches the supply side to fuse #13, via the probably-broken-wire rheostat behind the dimmer WHEEL in the main headlight switch.
Death awaits you all with nasty, big, pointy teeth.
1988 5.0 Bird, mostly stock, partly not, now gone to T-Bird heaven.
1990 Volvo 740GL. 114 tire-shredding horsies, baby!
Bypass the switch
Yup that switch it believe it is broken i have no bad wires and i dunno about the bulbs too freaking cold to keep messing around out there.  The other dash lights, i.e. HVAC panel, headlamp switch illumination don't work.
2004 Impala
