Topic: quick question (Read 1277 times) previous topic - next topic
quick question
i have an 86 mustang with a 5.0 and a 5 spd, i want to put both in my 87 tbird with a v6 but until i get time i would like to know if the 5.0 will bolt to the aod from the tbird
quick question
It will bolt up.
Why not put the 5-speed in it?
quick question
i plan on it, but for now since this is my only car i just want to hook it up and go instead of having to fix it up with a clutch pedal and make a hole in the floor for the shifter, i will save all that for when i have more time
quick question
That aod from the 3.8 will be weeker,less plates,
with that ho take care.babbie it till you get the time to do 5spd.
quick question
v6 aod will not take that 5.0 for long, not long at all so id drive the mustang till then if u can
quick question
would that be an A4LD tranny in the 3.8 birds? The AOD is a whole different tranny than the A4ld.  The AOD is what the 5.0 stangs came with Why would it have problems holding up to a 5.0? Now with the A4ld I could see that it would be weak. They even made the turbo models run less boost with the a4ld.
quick question
my mom wrecked the stang so that is why  i don't drive it and regretfully will rip it apart
quick question
Quote from: ipsd;108047
A4LD is available in 4 cylinder T Bird and Cougar.
all 3.8 V6 TBird and Cougar can have either AOD or C5 transmission not A4LD.
quick question
The V6 AOD is still known to be weaker and it's V8 counterpart... which doesn't have a great reputation to begin with. Especially when it comes to "strength". But you can build it up nonetheless if you choose to keep it in.
Personally I would just go ahead with the 5-speed swap. You've got all the parts and what better time to do it than an engine swap. Plus who knows how long that AOD will last. =/
