Topic: exhaust help (Read 1618 times) previous topic - next topic
exhaust help
i have an 87 tbird with a 3.8 v6, i also have an 86 mustang gt, i wanted to know if i can put the exhaust off the mustang with a 5.0 onto the tbird v6
exhaust help
Put the 5.0 in there while your at it :D
I dunno about bolting to the engine but I know you have to extend it 8" before the ler and another 10-ish at the tailpipe.
exhaust help
0i dont think so. the cat back "might" work. ive never put a dual exhaust on a v6. the manifolds wont work obviously. the h pipe likely wont bolt up to the tbirds manifiolds. as specially if the v6 has cast manifolds as well.
~John~
exhaust help
yeah, will not work unless you put the v8 in there with it... waite... why dont you put the 5.0 in there too, i mean sence your already taking the exhaust.
exhaust help
Anybody that can cut and weld can put that system on.. I didn't know my Bird has fake Dual exhaust not even a good connection on the Y pipe then too dual lers.. I am finding out real fast you can't just put the V-8 in there...
exhaust help
I think this guy wants to bolt the Mustang system up to the V6 manifolds WITHOUT welding.
I can pretty much guarantee that it won't work.
Find some headers from a late '90's 3.8 Mustang and custom fab an exhaust if you want true duals.  The only Ford vehicle that came with the 3.8 AND dual lers were the supercharged MN-12's and those wer a quasi-dual exhaust much like the 88 5.0 t-birds and cougars.
exhaust help
Depending on your location I have a custom welded dual exhaust setup for a Tbird/Cougar with a 3.8 that will bolt to the manifolds that I can sell you.
exhaust help
also, cat back is different on thse as well cause of the independant rear. that is, if they were all indepensant. was it only the super coupe that got those?
~John~
exhaust help
i plan to put the 5.0 in it, it is the only car i have though so i am waiting till the 3.8 gives out for an excuse, i just wanted to know if the manifolds would bolt up, it looked the same from under the hood, but i just wanted to find out before i took it apart, why waste time huh? The mustang i have was wrecked so i can use most everthing i need out of it including the 5 spd, but until i have time does anyone know if the motor will bolt up to the 3.8 aod automatic, i know i will probably have to change flywheels
exhaust help
slamedcat, i live in stockton, ca, how much do you want for the setup?
exhaust help
There may be a problem shipping it since it is one piece from the mainolds to the lers. This means its over 6 foot long.
That and it only has 2 cats in the system. Since you live in Ca would there be a problem with emissons on it?
exhaust help
the V8 manifolds deffinetly wont work on a V6.
~John~
exhaust help
Shame302 hope you are having a Good Day..
exhaust help
i don't know , i could probably put some 3 way cats from a later car to pass smog
