Topic: Late model motor mounts question (Read 1122 times) previous topic - next topic
I managed to find and buy 2 brand new left side upper bracket for 87-88 5.0 T Bird and Cougar but passenger side upper bracket is like needle in haysack.
I've seen plenty 1989 and up T Bird and Cougar V8 engine bracket. I was wondering if they'll fit 87 Cougar K member?
Has anybody here try to use late model 302 V8 1989 & up T Bird and Cougar  motor mount bracket in 87-88 T Bird / Cougar?
My gut feeling tells me it will work with little or no modification.
If I remember correctly you have to use the 87-88 Cougar/Thunderbird mounts as they are uniquie to the K-member. Mustang or Mark VII mounts won't work unless you swap in a Mustang K-member.
Quote from: thunderjet302;107362
That is correct....
frame bracket is different from Mustang.
The part I'm wondering about is the upper engine bracket. The part that bolts to engine block.
Anyway, I should explain more clearly on my first post. I wondering if 1989 and up T Bird and Cougar V8  mounts will fit on 87 -88 T Bird and Cougar.
yeah i tied it and the did not line up correctly
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
I won 89-96 T Bird V8 motor mount assembly on eBay .
I'll figure out something and post here. I know for facts that rubber isolator will be discard.
 I'll figure out something to do with upper and lower bracket.
The lower brackets are not the same.  The upper brackets should be the same.
I have Both for the 88 Bird complete . Pm me if interested...
