Topic: Westley's bleach (Read 1169 times) previous topic - next topic
Westley's bleach
Whoever here told me to use that, you are a God. It got the  off my turbines and tires and really took the shizznahh off my white lettering. I have another method to add to the mix though. Worked perfectly!
Westley's bleach +
= MEGA WIN
The magic eraser effortlessly got the grime right off and also deteriorated right away, but did the job. I will try a heavy duty pad next time.
Anyway, turbines are more clean than ever now. I threw away all the other wheel cleaning .
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Westley's bleach
Your welcome! Don't go to a heavier pad though, it will scratch the f&^# out of aluminum wheels.
Westley's bleach
*Update* used pretty much the same combo on my engine bay 22 year old crud came off no problem and now it looks pretty much brand new.
Westley's bleach kicks @$$
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Westley's bleach
GM brand White wall cleaner works really well on raised white letters. Also eats bugs and dirt/grime off of your car.
Westley's bleach
castrol super clean, purple power,greased lightning will yeild you the same if not a better result. May keep it in mind next time you are at the parts store ;)
Anything to make the job easier is worth every penny~!
Westley's bleach
I used this new labeled bottle  of simple green (says pro grade) on my tc wheels today and it really took some crud off..  Didn't hurt my hands either.
