Topic: headlights (Read 10975 times) previous topic - next topic
headlights
Reply #45
Could be any number of things..... Youv'e checked the obvious (voltage and fitment)  Did you swap the bulbs to see what happened?
headlights
Reply #46
Same no matter which bulb is in which socket. Put my old passenger lens on the driver side and it appeared to have the same beam pattern as the other passenger lens, although dimmer (older lens). Just doesn't seem right as to how the driver side lens has a lot of light loss, for no apparent reason. Its not like its more focused in a different pattern, its just "missing" light that should be there
I'll check the grounding on the driverside lamp and retighten it tomorrow. If I remember right though, it was dimmer/smaller than the passenger side even before the relay was installed.
1988 Thunderbird Sport
