Topic: 2.3 sputtering real bad (Read 2649 times) previous topic - next topic
Quote from: 88cat
Well my fuel pressure is good and i have adjusted it more or less and the same. Could it be a intercooler coupler leaking acking as a vacum leak?
Quite possible.
If any of the intercooler couplers were leaking you'd know it because it would barely make boost.
Quote from: Sick88Tbird
and you would hear the boost leaking
I will ask again, when you changed your spark plugs, how did they look...was any cylinder worse than others?  Did the car sit for any extended period of time?
Have any of you pulled KOEO or KOER codes?
Quote from: 88turbo
I'm not sure how to pull codes :dunno: there should be a sticky about pulling codes
I've posted it many times but it gets lost in the depts of page 2,3,4.....10...567
