Topic: How Do I remove Fan Motor??? (Read 2417 times) previous topic - next topic
Take your thermastat out and put it in boiling water, see if it opens.  If it does I would say replace the Water Pump, generaly no core exchange and only abour 40 bucks to get one.  The fact that the AC triggers it to overheat faster makes it think Water Pump, heater will quickly drop the temp.
Does the temp gage seem to bounce on you? Like go from normal temps to almost (but never quit hitting) red? then quickly back down when you hammer the gas or turn the heater?  If so I would say wit 99% assurity its the Pump, but that's just my opinion I'm not a certified mechanic.
Quote from: jackstraw
The fact that the AC triggers it to overheat faster makes it think Water Pump,...
A/C will always make a car run hotter, that's why cars with A/C usually have heavy duty cooling. In addition to the increased load the compressor puts on the engine, the condenser preheats the air being sucked through the rad, which will drive the temp up. In your owner's manual the first thing it says to do if the temp gauge is reading high is to turn off the A/C...
