Topic: Its about time. (Read 2138 times) previous topic - next topic
Its about time.
No it wouldnt. It needs heads also.
Its about time.
I would pull heads at a junk yard before an engine swap. At least get the turbo bird going before the engine swap.
Its about time.
could be,... Working when you dont have a car sucks though.
Its about time.
screw that drive the bitch pull the radiator cap so it dont get hot or build pressure. keep some h20 in the car it's warm enough now for that.. and worst case. pull the valve covers off and re tourqe the heads see if that works . till you get the tc working again
Its about time.
dude! i'm here to help! what do you need? you know parts are always free! oh yeah, i need help moving on saturday.:D(sucker!):D
So you have a V8.......isn't that cute.
