Topic: performance distributor module (Read 1577 times) previous topic - next topic
ok i bought this performance distributor module that replaces the stock module. now this is real urgent guys cuz i have a ford mett at QSL in clearwater. I need to know how to put this thing in idk what kind of screws those are that are holding on the module but also idk what else i have to do to install this thing.... i bought it 5 months ago and has been laying on my dash collecting dust here is a picture if u need something to work off of.
Go to a parts store, they sell a tool that makes it easy to remove.  Some of them are angled rachet wrenches and some of them are small knurled round things.  The screw type is usually a small Torx head or a very small hex head.  Make sure you put white thermal grease on the back of it.
what does this thign do for me? i heard it smooths out the idle and possibly saves gas
it works
Um I dont know about your 87 V6, but that wont work on my 88. Maybe the 87's still had the module on the distributer?:confused:
Yes, the 87's have the module on the distributor. Yours has a remote mount.
Ok, thats what I thought,  mine is on the core support.
ok i cant see what kind of screws are in there. their is a bar on top that is on the thing that holds all the things connected to the belt. idk how to take that thing off?
Quote from: 87fordboy
I run a Holley Annilliator TFI with a Crane PS92 coil in my Bird.. Are they any better than stock??? Not that I can tell... At least hopefully its a better quality than the Chinese replacements.
The screw that holds the module is a 7/32"(maybe it's metric, but my 7/32 Snap-On deep socket fits perfectly). As others mentioned the auto supplys sell a special tool just for this job. Likely the distributor will have to be loosened and turned a bit for acess. Means it should be retimed with a light.
Quote from: TurboCoupe50
The Metric equivalent is 5.5mm if i remember correctly.
ok i got the special tool now the altenator bracket is in the way so what do i do to gain full access to those 2 bolts?
loosen the distributor. CHange the timing, and hope you get it backon right.
If you can't figure it out, quit while your ahead.
Quote from: CougarSE
+1
