Topic: turbo upgrade problems...new nightmare :( (Read 7196 times) previous topic - next topic
Quote from: Red_LX
Are you sure the nuts are working loose?
everytime this happens atleast one of the nuts have worked loose.  the last time I put it together I used high temp RTV  and it held for about a month and a half.
here is what I have come up with since I blew my turbo last weekend....  http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=330013307724&ih=014&sspagename=STRK%3AMEWN%3AIT
Isn't that turbine housing missing something? Like an elbow?
no elbow..  it might not even work for my set up since it came from a motorcycle    :wtf:  :dunno:
Quote from: 88turbo
Seriously?
That thing is tiny....I doubt it's even a T-3 from the looks of it.
Quote from: Chuck W
Seriously?
if this doesnt work for me it will go back on ebay and I'll get another TO4E :mad:
I dont know what the deal is but even with a new TO4E I still cant make more than 5psi of boost what is the deal??  :mad:
Check your vacuum hoses? I had a hole in one of my lines and I couldn't boost for shizz. Have you checked the fuel pressure under boost/WOT? Ran any codes?
Reply #39
I ran codes when the problem first started and came up with my tps problem but I have since fixed it.  the car runs fine and feels good with the 4.5 psi or so that it is making would dist. timing have anything to do with it? I think I have it set at 14*  I miss my boost :(
Reply #41
Is the WG flapper closed all the way?  Could be bleeding off boost.
Reply #42
you know I did notice some carbon on it but I didnt think anything of it until I put it all back together.  that could be my problem right there.  carbon not letting the flapper close all the way. I'll open it up this weekend and see what I can find.
Reply #44
cam timing?  I havent changed anything since it came back from the shop after blowing the head gasket.  the car runs really smooth but wont boost at all with a new turbo.  I am leaning tword the carbon on the wastegate door but I havent fealt like taking it apart :flame:
