Topic: I broke down and bought it (Read 2044 times) previous topic - next topic
polarcat: i'm in allen county smackdab between lima and findlay.
Quote from: t-bird85
heh that was supossed to be "hope you dont":hick:
 I figured that is what you meant,was just rattling your cage.
 Your set up is just about the same as mine,but I am running 4.10s,GT40 intake 65mmTB 24#inj,10.5+ compression and Edelbrock Aluminum heads.
You better put a bigger fuel pump in there if it is still the stock pump or you will be picking out piston material.
