Topic: Cage finally painted (Read 4460 times) previous topic - next topic
pic didnt show for me can you send it to my email?  kurtdonaldkobain6794@yahoo.com  thanks
Quote from: Chuck W
Just two Shawn? :giggle:
if you want to send me 3 or 4, that would be great ;)
That looks fantastic. Nice work!
Quote from: 88turbo
Odd..try the link
HERE
Looks sweet Chuck.Obviously you arent going to have a back seat, what are your plans for taking up that space?
 Thanks,
  Chris
Chris-
No real plans for it other than ditching the seat.  I'm going to use some ABS plastic covered with carpet to cover the bulkhead between the cabin and the trunk.  Don't need to add any more weight back there.
Not gonna do much with the seat area other than possibly mounting the small battery in the spot behind the pass seat (I may mount it down lower instead).
Nice cage.  Painting it the same color as the car looks good.  Kind of brings the outside in.  Excellent work.
Or does it bring the inside OUT??
-Jim
1987 Cougar LS 5.0
Chuck
 Instead of ABS plastic have you thought about that thin wood at Home Depot? You know the stuff that is kinda rough on one side and very smooth on the other side? Might be cheper then the ABS also and just as easy to work with.
 Chris
I can get a 1/16" sheet of 4x8' black ABS for under $20, and that's going to be a hell of alot easier (flexible) to work with than wood.  I'm going to have to make holes and then slit it to be able to slide it up into place around the bars.
I have one sheet I'm going to use to replace the headline backer in the Z-7 with since it's a bit damaged and I may have enough left over to do what I need with this.
Ah ok.I never saw ABS for sale so I was unaware of its price.Where can you get that at?
 Thanks,
  Chris
chuck, where are you getting the abs? my local hardware store only sells plexy glass and its expensive...
Look in the phone book under plastics suppliers.  I found a place about 10 mins from my house that sells it.  I need to go back and pick up another sheet or two here soon.
Love the car chuck, what do you expect to be running in the 1/4? I will have to post some pics of my cage when i get it...
No idea of 1/4 times....not my thing...
