Topic: Intercooler fan install (Read 2523 times) previous topic - next topic
Re: Intercooler fan install
Quote from: Haystack
How does an intercooler mount on a tc? Is it horizontal at the hood scoops, or does it stand up, or is it on the under side/front of the car?
old pic:
Quote from: 460 turbo truck
hhah....no to be a dick or some thing, but those fans only push out a max of 100 cfm's
you'd be slowing down the air flow, unless you were stoped,
The three wires on the fan are yellow black and red i'm assuming, obvously one is ground(black) and one is positive) red and the other wire ( yellow) is a rpm send unit, tells the mother board how fast, not contorls the speed,
EDIT
PS. the fans will work fine under 11-15 V's
Yeah, the guys have already convinced me to drop those fans. Read the whole thread to see the conclusion. :)
Have you figured out if you can fit one of those fans from Summit in there?
Not yet. I spent the weekend in Calgary and driving around the mountains. Picked up the inlaws at the airport down there, so I imagine I'll be too busy for the next two weeks also.
