Topic: Someone please tell me..... (Read 4062 times) previous topic - next topic
New radiator came in.... I opened the box...A very sturdy box....and then there was ANOTHER BOX!  LOL!  That one was even MORE sturdy.  I opened that and found the radiator that a friend runs which is exactly what I was hoping this was.  It makes my old 3 row look tiny.  Gigantic core.  Even the tank on the passenger side is wider (driver side tank is about the same).
 http://www.mustangsunlimited.com/itemdy00.asp?T1=M8005A+01
I forgot how weird the tranny coolers are in the radiators on these cars.  I can't see them doing much now that I actually took the time to look at it closely.  Glad I run a big one mounted right in front of the radiator.....  My plan is to move it a bit more forward though as to have more space between it and the rad.  I'd like at least 3/4".  It's pretty much mounted to it right now with those tabs and feed through style zip ties.  I'm sure spacing it out will help some.
My S197 comes with a pretty decent front mount trans cooler straight from the factory.....  Guess the manufacturers are learning from the racers still.
Quote from: daminc;435905
I'm sure I'll be right behind you in fixing things, Paul....almost everything in my car is still all original either from my car, or the parts car that I used.... the radiator in my car is still factory also
Swap that rad, Jerry.
Hopefully that radiator will make your car run nice and cool. It looks like it should. I had the Thunderbird out for a half hour drive Tuesday morning (air temp was about 59*-60*). About 25 miles round trip. I got the car back in the garage and popped the hood. The coolant overflow was about 1/2"-3/4" above the full cold line. The upper radiator hose was warm/hot. I touched the bottom hose and it was maybe a couple degrees warmer than my hand. I could comfortably wrap my had around it. Summit two row aluminum radiator with an 180* thermostat, police interceptor fan clutch, and a 9 blade fan. I hope your new radiator cools that well :).
You know what's funny?  If you look at the Summit Radiator photos, There's a logo on it with script writing along the side.  The aluminum radiators the local speed shop have the very same logo on them.  Of course when I check my local place's website they don't list them, but then again they don't list about a quarter of the stuff they have.
I actually contemplated a nice Griffin piece, but I really do not think it will fit my setup and would need to convert to electric fans for space.  The one I got was in place on a car with the same heads as me, a b-cam, GT-40 intake, and an older style V-1 vortech with about 7 lbs of boost.  Car had full A/C too.  Cooled it fine.
The worst thing you can do to a car is let it sit.
I've only daily driven these cars for the last 10 years and i can count on one hand how many times they let me down, and it was generally something i did/screwed up.
I've put well over 50k miles in a year with few if any problems. in my opinion most people just don't drive them enough.
When the paint issues arose right after the repaint a couple of years ago, I considered parting the car out or selling  it.  I was supremely disgusted.  Last thing I wanted to do was drive it then.  I would start it,let it run, and take it for a 5 minute ride about once every 2 or 3 weeks just to make sure everything stayed somewhat functional/lubricated.  Pissed me off every time I walked over to it and looked at it though.....  Tomorrow everything goes in.  Weather is supposed to be perfect, wife & kids will be out (no interruptions. ;) ), and I am off from work.  Gonna be a good day.
Now you should be able to drive the car and it should stay nice and cool :)
Done.  Drove her around a bit.  All seems well.  Had a slight leak from one of those quick disconnect fittings on the trans line.  Got another half turn on it as it was a wee bit loose.  Should be good now.... Gonna test it in a minute.  I hate those fittings.
