Topic: Timing a possessed Cougar. (Read 17967 times) previous topic - next topic
Reply #45
i would compression test first,, Happy thanksgiving by the way.
sorry to hear about your recent funeral, i meant to mention that the other day.
Reply #46
Compression TEST Then true TDC in that order!!!
Reply #47
The compression tester is definitely not the best, Even the compression fitting leaked. Here's what I got:
#1- 140lbs., #2- 150lbs., #3- 140lbs. #4- 150lbs. #5- 140lbs. #6- 140lbs. #7- 130lbs., #8- 130lbs.
That's about as good as it get with my cheap set up. Tom, I know you aren't liking these numbers and probably for good reason. Now I'm going to check true TDC.
Reply #48
I have all the plugs out, I have the belt off, so how exactly do I turn the engine over by hand... not to mention watch the screw driver at the same time? Seriously, I think you would have to be a grease gorilla not a grease monkey to pull that off (lol).
Reply #49
You guy's have a great Thanksgiving Day! Enjoy yourselves!
Reply #50
Turn the crank with a socket and a breaker bar. It is easy i do it all the time.
Reply #51
I don't know why I thought this car didn't have a bolt on the end of the crankshaft. I moved it back and forth several times and to be honest, I couldn't feel any slop. I went by the screw driver in the #1 cylinder and the degree marks on the damper was almost perfect, maybe a degree off.
Reply #52
jcassity,
            I will use your post and set the timing tomorrow.
Reply #53
What post would that be . The one from the BLACK FOREST that little ELVES WROTE. Hook the light to it with the Spout removed and line up the marks. If the TFI winds up at or around 4 o'clock you are good. (That is if this dizzy has one???)  If not re index it and you are DUN!!!
Just for kicks post a photo of the DIZZY. I am curious about something???
Reply #54
Ok the chain is good to GO!!! Those readings are not the best by no means but it will run!!!
Reply #55
Quote from: TOM Renzo;403031
Now THAT was funny!!!
Reply #56
Geez! I can't stop laughing!!
Reply #58
Nice going JAY. I figured a little humor to break the ICE and the TENSION!!!
Reply #59
I'm pretty sure I have the timing set up right. The rotor pointed toward 11:00, and the Tfi module pointing at 4:00. I tried to start it and it sounded like it was trying to but it never did. So, I charged my battery up again and I went over to check the voltage on my TPS and now with the battery charged if I turn the ignition to "run" I keep blowing out the same fuse like like before. I tried about a 22 gauge wire and it blew also. Back to the drawing board.
