Topic: Headlamp HI/Low relay mod **complete (Read 3476 times) previous topic - next topic
got it all done today, not much to look at from the outside but its all good.
here are the final drawings, watch out for the red / yellow, both of them need to be intercepted,not just one.
if you only intercept one lead that goes to the M/F switch, load current will **NOT** go through your relay mod if you have "Auto Lamps".
I also sourced power for the exterior lamps differntly, we are getting power off our new fuse block instead of tapping into the oem power feed.
we powered up our fuse block from the starter relay with some 130degC #8 , frame ground with same spec wire up to a bracket thats around the steering shaft..
ok, all the work was **WELL** worth it.  such a small amount of parts can make such a difference.
The lights are reasonably estimated to be at the very least 40% brighter.
I swore he had high beams on when it was low.  Putting on high beams made me see spots....
Glad we did it.
Have you considered making these panels and selling them, to us less adept owners?  :)
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
i could, easy enough to build out for certain.
the material list is not too overly expensive for parts.
if someone supplied the parts and shipped it here, i could assemble to include all wiring with instructions to intercept yours.
Quote from: jcassity;396805
You good sir have a pm. :)
