Topic: A little before and after action.... (Read 4622 times) previous topic - next topic
i was just kidding.. it just looks like it's sitting a lot taller with the low-pro's.. what were the wheels in the 'before' pic, 14's?
Quote from: jrad235;372993
I dare you to measure 347Thunder's or Jerry's car. I bet either one is within an inch of the ride height on mine.
mine is def raised up... I also have oversize tires...
I'm going to measure it today
I got 26-1/2" in the front and 27-1/2" in the rear
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
I got 28'' in the front...29'' in the back
Heres one of mine      XX
Well, I think I was right about one of those cars...:mullet:
I'll have to double check mine to figure out which one though! Technically, those low-pro's are a touch smaller diameter than the originals, which were 14's. When they wear out I'll get something with a lot more sidewall.
Quote from: gumby;372935
Not much different on mine....
After
Gumby I would love details on how you got that stance. Or if there is a thread somewhere already if you could point me to it I would greatly appreciate it, if there isn't a thread maybe you could start one. :D
...and there was light!
Quote from: jrad235;373019
that's what i thought.. the originals wheels didn't look all that big.. i have similar wheels but they're 16's wrapped in 235/65's and fill the wheel well more than that
before
after
BTW:  Mines 25 1/4 all the way around
^Wow nice dude!^ Gorgeous car!
Not a huge difference:
before
after
Looks like 27.5" up front, and 28.5" out back. Sounds like I split the difference.  As far as the tires go, the originals were 205/70R14, and the new ones are 225-235/40R18's. I believe the rough diameter on both of them is 25".
X
Mine got worse....
Just how I bought it, minus the TRX wheels
After 4 years of learning to drive, being replaced as the DD, and parked for 2 years
