Topic: BM's 88 Cougar build (Read 42875 times) previous topic - next topic
I changed the timing chain, it wasn't that bad, took about five hours. It idles and cruises alot smoother. It doesn't spark knock anymore. But the fuel mileage still hasn't come up where it was when I bought it. At 65 mph im turning about 1600 rpm and its getting 21mpg. When I bought it it got 28mpg. I don't knoe the average mpg yet.
I got a heater core for the Cougar today. On the box it says that its for a 79-93 Mustang, 79-88 Capri, 80-88 T-brid, and 80-85 Cougar. I could be wrong but I thought that the T-bird and Cougars were the same from 80-88. Why does the box say that its only good for 80-85 Cougars? Is the box wrong? I'll post pictures soon.
Does this look like the right one?
It looks like the same one I put in my car several years ago.  If its for a 80-88 'bird, it will fit your car.
Thats what I thought. I dont know why the box says 80-85 Cougar.
Thank you.
It's the correct one.  Throw it in.
I GOT HEAT!!!! Thanks to Cool Cats. The right up on Cool Cats was very helpful. It only took about three hours. I was also fortunate that my freind let me do it in his heated shop (29* today).
WOO-HOO !!!! Now,don't you feel better?
Hell yea! After everthing I've done to the car, I'm the happyest about the heater core. The guy that let me use his shop gave me all the gaskets for the top end of the engine (still need head gaskets). After I find an exhaust valve for my GT40 heads Im going to reseal the top end of the motor. I've got SS 1.94s & 1.60s for the heads but thats for the next stage. Right now Im just going to put them on stock. I only have money to patch it up for now. Ford wants $63 for a 1.54 exhaust valve and I cant find it in any of the parts catalogs at the head shop (only can find 4-barrel windsor valves and they have the wrong tip length). Early model valves have .395" tip length and late models have .480". I haven't checked any part store yet.
Reply #39
Go to any machine shop that does heads,they can hook you up. Autozone also has them and can get them for you cheap.. A valve is pretty cheap.
Reply #40
I know I use to work at a machine shop for five years and what sucks is we were a cylinder head shop. I could'nt find it in my old bosses catalogs and he did'nt sound very interrested in helping me. The only listings were 1.45 GT40Ps and early model 1.55 4V windsors. It shouldn't cost more than about 7-10 dollars. I have all of the measurements 1.54X5.09 with .480 tip. I'm going to check with a local engine part supplier that I use to deal with (Factory Parts) but I think you have to have an account.
Reply #41
Not much to add lately. I changed both U-joints today. The front joint was wasted, one of the cap didn't have any needle bearing left. They were a pain in the a$$ too. I don't know why but they were a pain.
Reply #42
So, Im getting a good tax return and my lovely wife has agreed to let me build a short block for the cougar. Just a cheap stock rebuild with flat tops. Im also going to run ported E7s with GT40 intake valves. I gave my GT40 heads to a freind in trade he's going to balance my crank and stuff. The E7s are already done and this way I will'nt have to buy stud mount RR. I do need some stuff like a HO cam and computer. I thought I had the cam but it's gone. Do any of yall have a cam or computer.
Reply #43
Those cams (stock H.O) usually go pretty cheap,and are actually very good cams. Check over on the Corral and post your needs. There will be someone there who has those parts. Do you have the injectors already? If you're doing a rebuild,check around for replacement pistons. H.O pistons are a direct swap (you need new rings anyway during a rebuild),and you'll have forged pistons with valve reliefs as well in case you decide to get a bigger cam down the road....which may just happen.. Ask around.
Reply #44
I have injectors. I plan on running KB light weight pistons with two valve reliafs. They're only $300 and I dont plan on running nitrous or a blower. I have a set of HO pistons but my block needs to be bored.
