Topic: Got spark, Got fuel, no start. *TELL ME WHAT HAPPENED (Read 4383 times) previous topic - next topic
Quote from: Cougar5.0;254827
I don't know what ECU he is using,.
1990 351 EFI per post 1.
The reason this bugs me is because of a very old response i posted to someone that claimed they just hook thier tps up but didnt mount it.
I told them it wouldnt work.  Obviously it will and I have no idea why.
I didnt test my 20th, had second thoughts on inserting a code and the "if it aint broke , dont fix it" theory".
I assumed that "open" was the equivalent of WOT, but it should also have thrown a code as higher than 4.95V in A9L is above a failure limit. Without knowing the exact catch code (A9L, X3Z ??? for 351 EFI) for your ECU and looking at the definition in my tuning program (assuming it's even available), I can just speak in general terms about how the typical Ford ECU works. Don't shoot the messenger - I'm just trying to help. It took 1/2 hour to dig that info out of the strategy document for A9L which is the only really good Ford document available to me.
Quote from: jcassity;254834
it works on a 5.0
ive done it(car was running unscrewed tps, and it still ran and accelerated)
im not shooting the messanger, i just dont use enough emotions off to the side when i post.  Since Daboss says it worked on one of his 5.0's, maybe that catch code will be a template for you.  I have no idea what eec # i have other than eeciv.
Daboss...........
your dead on what happened.  This is what i am tring to figure out.  what signal is telling the eec that the trottle plate has moved.  without a tps mounted,, it would almost have to be map related.
I had NO acceleration issues at all, no power issues and no signs that it was richer than normal although the 351 does like its go juice.
Quote from: jcassity;254863
Daboss...........
my idle was way high, i took it off and I cant remember how it ran but I dont think it was too great. I will try it on my linc tomorrow since i could care less at this point, it cant hurt anything!
My guess is the IAC prob has something to do with it, since it mesures air flow, and can severely f up how the car runs. cause my idle issues were not TPS related only IAC
my 2 cents
daboss, doesn't the LSC have a 5L HO engine with a MAF - just like the Mustangs?
Quote from: Cougar5.0;254873
nope
87?-92 lsc was 5.0ho SD
never got MAF
Well, I guess that would be another example of a speed density car working without the TPS.
Scott's choices for a CPU code are listed below:
CODE ENGINE VEHICLE NOTES
39D1 5.8 Bronco, F-x50 E-x50 SD-Bank
8QF 5.8 Bronco, F-x50 E-x50 SD-Bank
8QJ 5.8 Bronco, F-x50 E-x50 SD-Bank / C6
A0C2 5.8 Bronco, F-x50 E-x50 SD-Bank / E4OD
A0C3 5.8 Bronco, F-x50 E-x50 SD-Bank
A2Z 5.8 Bronco, F-x50 E-x50 SD-Bank
A2Z1 5.8 Bronco, F-x50 E-x50 SD-Bank
BTQ 5.8 Bronco, F-x50 E-x50 SD-Bank
C1Z 5.8 Bronco, F-x50 E-x50 SD-Bank
C9S1 5.8 Bronco, F-x50 E-x50 SD-Bank / E4OD
D1X 5.8 Bronco, F-x50 E-x50 SD-Bank
D9D1 5.8 Bronco, F-x50 E-x50 SD-Bank
D9L1 5.8 Bronco, F-x50 E-x50 SD-Bank
D9J2 5.8 Bronco, F-x50 E-x50 SD-Bank / C6
E9C 5.8 Bronco, F-x50 E-x50 SD-Bank / C6
E9C1 5.8 Bronco, F-x50 E-x50 SD-Bank / C6
E0D 5.8 Bronco, F-x50 E-x50 SD-Bank / E4OD
FK1 5.8 Bronco, F-x50 E-x50 SD-Bank
U2U1 5.8 Bronco, F-x50 E-x50 SD-Bank
W2J 5.8 Bronco, F-x50 E-x50 SD-Bank
X0P 5.8 Bronco, F-x50 E-x50 SD-Bank
X2Z2 5.8 Bronco, F-x50 E-x50 SD-Bank / E4OD
Z2D1 5.8 Bronco, F-x50 E-x50 SD-Bank
I can't find an ECU catch code for the '90 LSC.
Edit: I found a code for the speed density Mustang (87-88) and it's just not complete enough - failure mode stuff isn't there. I'm just going to assume that the MAP sensor is used when the TPS fails until someone can find information that states otherwise.
I cant remember 100% so im gonna try it.
Ill get my comp code as well.
You were in FMEM, but not HLOS.
Descriptions of both below....
The EEC-IV system is capable of storing both ongoing ("hard'') and intermittent ("soft'') faults. As a result, it is possible to monitor irregularities which may not be immediately present.
While the EEC-IV system is capable of recognizing many internal faults, certain faults will not be recognized. Because the computer system reads only electrical signals, it cannot sense or react to mechanical or vacuum faults affecting engine operation. Some of these faults may affect another component which will set a code. For example, the PCM monitors the output signal to the fuel injectors, but cannot detect a partially clogged injector. As long as the output driver responds correctly, the computer will read the system as functioning correctly. However, the improper flow of fuel may result in a lean mixture. This would, in turn, be detected by the oxygen sensor and noticed as a constantly lean signal by the PCM. Once the signal falls outside the pre-programmed limits, the engine control assembly would notice the fault and set an identification code.
Additionally, the EEC-IV system employs adaptive fuel logic. This process is used to compensate for normal wear and variability within the fuel system. Once the engine enters steady-state operation, the engine control assembly watches the oxygen sensor signal for a bias or tendency to run slightly rich or lean. If such a bias is detected, the adaptive logic corrects the fuel delivery to bring the air/fuel mixture towards a 14.7:1 or "centered'' ratio. This compensating shift is stored in a non-volatile memory which is retained by battery power even with the ignition switched OFF. The correction factor is then available the next time the vehicle is operated.
If the negative battery cable is disconnected for longer than 5 minutes, the adaptive fuel factor will be lost. After repair, it will be necessary to drive the car at least 10 miles to allow the processor to relearn the correct factors. If possible, the driving period should include steady-throttle open road driving. During the drive, the vehicle may exhibit driveability symptoms not noticed before. These symptoms should clear as the PCM computes the correction factor. The PCM will also store Code "19'' indicating loss of power to the controller.
Failure Mode Effects Management (FMEM)
The engine controller assembly contains back-up programs which allow the engine to operate if a sensor signal is lost. If a sensor's input is seen to be out of range-either high or low-the FMEM program is used. The processor substitutes a fixed value for the missing sensor signal. The engine will continue to operate, although performance and driveability may be noticeably reduced. This function of the controller is sometimes referred to as the limp-in or fail-safe mode. If the missing sensor signal is restored, the FMEM system immediately returns the system to normal operation.
Hardware Limited Operation Strategy (HLOS)
This mode is only used if the microprocessor fails to operate, or if the fault is too extreme for the FMEM circuit to handle. In this mode, the processor has ceased all computation and control, and the entire system is run on fixed values. The vehicle may be operated, but performance and driveability will be greatly reduced. The fixed or default settings provide minimal calibration, allowing the vehicle to be carefully driven in for service.
From what I understand, HLOS locks out the dwell and spout for a fixed spark signal throughout the rpm RANGE.
I've never had a properly working TPS. I have started the car without it hooked up before too. As far as I can tell, I think the TPS is only for idle. It seems to idle okay without one as well.
I find it odd that there isnt a code that tells the us that the engine is in / was in limp mode.
Quote from: jcassity;255320
There is... Code 98, but it only display in KOER mode... Basically it's telling you to run KOEO tests again, that will point to the problem...
It's not going to limp mode with the TPS connected and hanging, in fact will pass KOEO with flying colors... Guessing it may show a fault KOER, if not should set a code after driving at speed...
In a SD system, the MAP is king and will cause a major over fuel condition if it has no vacuum(I'm 99% sure the EEC will "piss the fuel" on low vacuum, whether there is a varying TPS sig or not)  ... If you want some cheap neons, just run the engine with the MAP vac disconnected... The area around your car will glow brightly just before the catalytic converter burns up(along with the car)...
LOL! Nice!
Quote from: Haystack;255317
Nope TPS tells the computer how far the throttle is open. That way the computer knows what position you have the throttle at based on what voltage signal the TPS puts out.
