Topic: 1.7 on HO Conversion? (Read 4997 times) previous topic - next topic
Quote from: Sick88Tbird;234131
Actually you do NOT have flat tops...flat tops are just that...flat...no valve notches...go pull the heads off an '86 HO...now those are flat tops.
I know *flat* tops have no notches. I've seen plenty of 86 HO pistons. My pistons (even though they have valve notches) are flat topped vs stock 87-93 HO pistons as those have a dish around the valves, where as mine do not.
cant flat top also mean they are niether domed nor dished? i mean thier not perfectly flat all the way across cus of reliefs, but thier otherwise flat?
Quote from: 1WLD BRD;234097
I have pretty much the exact set up as Vinnie....  I dont think they would clear with a 1.7 RR....
what Im wondering is.... Why are you bothering with the E6's to begin with?  they are boat anchors...  s em and go E7's
the t-bird is going to be more then fast enough. im not going to try and make the cougar my hotrod, i dont want two money pits. i just want a little more power and i've done  near everything a person can do to get power out of a SO motor, its time to go HO. im guessing 210hp now, figure cams good for 50hp, plus i have all new lifters pushrods and timing set. so 260ish maybe a touch more. not that bad.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
boy have you got alot more reading to do if you figure your cam is worth 50hp!
i said give or take.
in 86 the ho and the so used pretty much the same everything except cam, and made 200 where the so was 150. is 50 really that crazy of a number to claim?
Quote from: grutinator;234441
Depends...
If you're going to use it by it's self, then you'll be disappointed...
If you plan on using the larger TB & EGR spacer, the 19lb inj, HO EEC and headers with true dual exhaust system, then you'll have the extra 50HP... With a true HO intake, and the 1.7s, probably closer to 60HP...
Having half a point less compression with the SO pistons isn't going to help matters much.
Quote from: TurboCoupe50;234443
Depends...
mods-
bbk 1-5/8 shorty headers
flotech offroad h-pipe 2.5
flowmaster 50 series catback 2.5
H.O. upper intake, TB and EGR
1.7 RR
electric fan
pulleys
adj fuel pressure reg
and then little  like cold air, smog delete(that )
like i said, ive done pretty much everything i can do to a SO and still have it be a true SO.
and yeah, i'd put 19's and the computer too. i didnt specify but i just assumed that all that was required in any H.O conversion. heads are kinda optional, but you need that for it to run right. i'd also upgade the pump too.
Sorry I don't keep up with everyones mods, got more important things to worry about...
With the electric fan, headers and 2 1/2" exhaust, that ought give(free up) another 15-20hp...
