Topic: What I've been working on. (Read 1942 times) previous topic - next topic
Left is before right is after
Wet sanded and waxed.
What do you guys use to get the shine back?
BTW these will be for sale after they are done, but they are far from done, i need more sandpaper, and polish to get them to shine.
Before
After
Not bad for 2 hours work, but they need more work, more sanding, and tons more polishing
I used to use rubbing compound, polishing compound , than machine glaze. The machine glaze also worked great on my mirrors, windshield and chrome parts.
good to know! Thats what i was thinking, then i thought maybe a plastic rubbing compound and i know others have clearcoated them after wetsanding.
also working on some center caps!
top are not done, bottoms are started. These will also be for sale once completed.
try some glaze on those to. I used a cheap black& decker buffer on the light weight stuff, lower RPMs, no burn. I buff my guitars with it too.
they come out with a mirror finish
I definitely need a set of TC inner markers as mine have cracks... ;)
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
i use toothpaste to get the yellowing/fogging out of my plastic lights.
works fine and cost a dollar or less. probly should start using it for my teeth though:hick:
Quote from: Quietleaf;200382
these have some cracks the light little ones in the plastic u cant see till u turn it. they arent perfect but are in really good shape
Need to get this stuff gone so it will all be in the for sale section once compleated. Im HOPEFULLY buying a new mark so i need $$$
carpet fuzzies
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
The same one from the other post? or a differant mark
new one
another looks to be rot free 88
I HOPE.
bought some plastic polish to finish the lights tonight
are you hand polishing or by machine?
