LS1 heads on SBF!
Reply #15 –
ahh. why not just get custom pistons. no need for a special cam. and just throw a carb on it to run. then mill a 351w intake. if it's going to be cheap. the pistons will just be the the most expensive engine part. if he could install them himself on some rods.
but for the work he is doing id rather bolt a set of Clevland heads on and worry about changing water passages and a ford intake milld down or spacers. and run all ford parts. (guess youd still need pistons though due to canted valves) but hell ford did it! and you can even have EFi now. been done
