Topic: Would anyone be interested? Eaton M90 (Read 3049 times) previous topic - next topic
Not that I’m interested but how much are you asking
Ah you’re probably not going to say now that it’s on eBay.
I actually am interested, but I want to see how much more (if any) work is needed to make it work.
Isn't that m90 upside down????
How would you check change the oil and wouldn't the oil resovoir be on the wrong side with not enough gear lube??????
Actually, if you look at the GM cars, and how the M90 is designed to start with, the SC's mount them upside down so they can be intercooled. I cant remember if he used an SC M90 or GM M90.
Dominator: It wouldn't matter if it's upside down or on it's side. To change the oil, simply unbolt it from the upper manifold and fill/change/check. I totally disassembled the blower to check all the clearances and  ware. There were some small nicks on the rotor lobes, but I took care of that. Just to let you all know, I work in the compressor field.
V8 Demon: There isn't a whole lot of work left to do, just little loose ends to tie up. I'm actually still mess'n around with it. Just a side note, you will need to have a big cowl hood or just have it stick out your hood.
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
Ford Supercoupe M90
well...I haven't put it on ebay yet. Still messi'n with it....finished all the gaskets needed to seal it up and have new coolant for it also. All the posts about the M90 on a V8 bird or cat...I'm surprised I haven't heard from a lot of you...hummm. I guess it isn't a cool thing.
