Topic: A little Mustang update (Read 12340 times) previous topic - next topic
Reply #90
Looking real goooood keep up the work!
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Reply #91
Quote from: turb0coupe88;146157
wow, im in love with your cars.:shakeass:
Ill sell you my collection :flame:
J/k Thanks:D
Reply #92
making good progress. good job! what are the specs on the motor and carb?
1979 Ford Fairmont
[/B]
Reply #93
Quote from: 32VFoxBird;146165
89 mustang 2.3 block
Turbocoupe rods and pistons
E41K ring set
clevite bearings
N/A head with the chambers opened to unshroud the valves
1.89/1.60 valves .100 thou longer
.500 lift lunati camshaft
Lunati dual springs
Clevite lifters and tappets
Home done port job
Thats about it I want to push the stock shortblocks limits before i drop big coin into a stroker.
The carb is a 600 double pumper i got from mikey, Setup for blowthrough i also changed the boosters and rebuilt it myself
Reply #94
down pipe is done,Going to drive it tommorow afternoon and see were the A/F ratio is at
Reply #95
Where do you buy your intake tubing? That is some fast and clean work. Im amazed.
Reply #96
So now your done.....
Reply #97
Quote from: cougrrr302;146395
I usually get hookers or dynomax mild steel mandrel bends.I order them from a local speed shop cause they usually get the stuff next day as opposed to 2-3 days from jegs or summit:hick:
Thanks man,I take out my stress by building these clunkers:toilet:
Reply #98
Quote from: 84 Fila;146396
Yes,other then the tuning that will be involved it is done.
Reply #99
bitchin...,. can I get a ride?
Reply #100
Quote from: 84 Fila;146403
:evilgrin:
Reply #101
 after i got the air fuel in check this sum bitch runs!
I should had done a carb blow through a while back
