Topic: Soooo.... What kind of Fuel pump do you guys run? (Read 3000 times) previous topic - next topic
Oh by the way thunderjet i currently have a 155lph walbro that i used to have in my car,it's got like maybe 3000kms on it and never let me down,i can let ya have it for 40bucks shipped if your interested.
Try running 30 psi of boost on top of 48-50 psi of base pressure.
Why are you running that much base pressure? With 42# injectors, you shouldnt need anywhere near that much base.
I'm running a fuel pump for a "91 mustang GT.I ordered it when I did my H.O swap.Works great.
Quote from: vinnietbird;124019
How did you get that to fit in a non Turbo Coupe tank? I listed the link for the pumps because they come with the rubber isolator to keep the pump in one spot.
Quote from: dominator;123937
 it I just ordered a new one today. I should have checked this thread before I ordered the pump :brick:
My pump came with a new bottom rubber piece that actualy fit the hanger.
Mine came with the rubber and a sock.  It's a walbro 255 for a Mustang.  As fas as sputtering.....haven't had an issue yet and I've run it down to fumes.  I sat it as low as it would go on the hanger.
Well hopefully the pump I ordered will work. I'll find out in March.
I just ordered the pump and installed like you would if you ordered the T-Bird pump.I had no issues.Took all of 20 minutes (with the tank nearly empty).It's enough for my combo.If I get my wish and move up to a Mass Air 351W in 2008,that pump will come out and a higher flowing one will go in.
