3.8 motor mount to block hardware? Reply #15 – November 20, 2006, 10:32:02 AM I will when I get back in Ohio. Quote Selected
3.8 motor mount to block hardware? Reply #16 – November 20, 2006, 10:48:50 AM One thing that will make it easy. See if it threads into the threaded insert on the lower U-bracket for the long through-bolt. I know what that thread is. Quote Selected
3.8 motor mount to block hardware? Reply #17 – November 20, 2006, 10:58:28 AM Chuck, Just measured one. I have a 3.8 out in the garage on a stand. It is definitely a 10x1.5 grade 9.8 bolt. hope this helps....Joe Quote Selected
3.8 motor mount to block hardware? Reply #18 – November 20, 2006, 11:13:01 AM Ok, perfect. Thanks! It's amazing how long it took to get confirmation on this...from 3 different sites. Quote Selected
3.8 motor mount to block hardware? Reply #19 – November 21, 2006, 12:51:23 PM actual bolt measures 1 1/2'' long with 26 total threads,,as stated, its a 9.5 bolt with a 13mm head.chuckjust fyi,,,,the pass top front bolt is double ended so the batt ground can be connnected there.sorry i did not see this post earlier,, could have helped sooner. Quote Selected
