Topic: Cam Timing (Read 704 times) previous topic - next topic
Cam Timing
What if anything can I gain with a 4 Degree advance on a Stock EFI Cam.. Besides  the valves opening 4 degrees sooner before TDC..
More engine pics on the Bronco II Photo page, follow link below...
Cam Timing
Here's a general rule of thumb, advancing moves your power band down some rpm and let's it come on sooner, retarding it brings it on later and will usually net you a peak HP gain, albeit on the high end.  With stock internals and street gears I'd leave it straight up.
Cam Timing
Ok that's what I did , should work like stock..lol
