Computers/PCs => General Computer Forum => Topic started by: jkirchman on August 25, 2006, 06:21:35 PM
Title: Building A System
Post by: jkirchman on August 25, 2006, 06:21:35 PM
Time for an upgrade.  Give me your opinions.  Here is what I'm considering:
AMD Athlon 64 X2 4200+
ASRock 939 Dual SATA-2 motherboardKingston HyperX DDR400 RAM, 1 GB
Western Digital Caviar 120GB SATA-2 hard drive
I'll just use my current case since I like it and it is more than adequate.  All of this stuff will set me back around $400 from Newegg.  I figure this setup should last me a while.
Post by: armyguy298 on August 25, 2006, 10:41:29 PM
Looks like a good build! I know that I purchased 2 SATA hardrives and set them up as a RAid-0 config and those cant be beat! Programs load in half the time they used to! BUt even just the SATA drive alone will be a lot faster than IDE. Looks like youve done your homework!
Post by: kingcars on August 26, 2006, 12:33:20 AM
If $400 is your budget, that looks decent.  Although you might want to look into going with AM2 or maybe even a new Intel Core 2 Duo system, but you probably dont feel like saving any more :hick: .
Post by: jkirchman on August 27, 2006, 09:32:30 PM
The motherboard I decided on has a slot that will allow an AM2 processor to be used later on if I decide to.  I did a bit of reading and for what I'll be using it for I can't see a huge difference between 939 and AM2.  Plus, there are no AM2 motherboards that can be used with an AGP video card.
Post by: kingcars on August 27, 2006, 11:15:59 PM
You can get a PCI-E card for pretty cheap that will probably run as good (if not better) as that 9550.
Post by: bhazard on August 27, 2006, 11:43:50 PM
9550 is a total budget card, it would be a waste of the rest of that setup to use that card.
Post by: kingcars on August 28, 2006, 12:03:02 AM
Quote from: bhazard
Agreed.
http://www.newegg.com/Product/Product.asp?Item=N82E16813131033
http://www.newegg.com/Product/Product.asp?Item=N82E16814133154
Not the best, but it would be a big improvement along with that CPU you plan on getting.  If you wanna save some money, just get an X2 3800+ for $159; it's plenty fast.  Getting that 6600 will improve performance A LOT more than a 4200+ over a 3800+.  I doubt you'll even know the difference in CPU.
Post by: jkirchman on August 28, 2006, 01:24:33 PM
Say whatever you want about the 9550, but it runs the games I have quite well with its 256MB of memory.  Besides, I haven't had it that long and don't want to drop another $160 yet.  It won't hurt me to keep it, and then when I upgrade to PCIe I will enjoy the system even more, right?
But I digress.  Thanks for the links to the PCIe cards.  When I'm ready to get one of them six months from now, they'll be cheaper!  :D
Post by: GreyWolf30 on September 09, 2006, 07:47:02 AM
After looking at your choices (was allready familiar with the CPU and vid card), it seems to be an ok path. Further investigation into performance shows decent scores for the mainboard you are looking at. If it is the AM2 upgrade path you are looking at, forget it. The add in board, while it works well, is a tight fit. ( http://www.ocworkbench.com/2006/asrock/AM2%20CPU%20Board/g2.htm follow link and look at the second picture) Air flow for CPU cooling WILL be an issue and you will still have to buy DDR2 memory, which will be very close to the HSF. It is a large add-in card, and it currently costs about $50. Plus, look at all those jumpers you would have to mess with, ouch! In addition, the main power cable will go right over the top of the main CPU socket which will cause an air flow issue with either the 939 or AM2 setup. I would not touch it, period.
Consider these parts:
Vid Card: http://www.newegg.com/Product/Product.asp?Item=N82E16814143049 ($30.00 Rebate Available!)
Mainboard: http://www.newegg.com/Product/Product.asp?Item=N82E16813131569
CPU: http://www.newegg.com/Product/Product.asp?Item=N82E16819103562
Memory: http://www.newegg.com/Product/Product.asp?Item=N82E16820145450
Hard Drive: http://www.newegg.com/Product/Product.asp?Item=N82E16822148149
Total cost (with shipping) = $572.38 (before rebate)
 I know that this would require you to wait a little longer. However, it will be worth it!
I can tell you that this setup will work for you, unless you want to go SLI. If AM2 is what you are shooting for during the next 12 months, wait and save your money untill you can get the DDR2 to go with the requisite parts.
If you are dead set on staying with AGP, there are AGP variants of the NVidia 7600 and 7800 series cards on the market. You could do the following
Mainboard: http://www.newegg.com/Product/Product.asp?Item=N82E16813131541
Total cost (with shipping) = $417.03
As for Vid Cards, the 7600GT will spank the 9550 so hard I will hear it cry for it's mommy all the way up here in Detroit!
btw, what is your current power supply?
A side note: I have been researching and building game rigs for almost 7 years now. While some features may look good, they can be fairly cumbersome to implement even if they work. Sure, the ULi (formerly ALi) chipset is good, but the AM2 upgrade board seems more of a gimmik than a really useful feature. While it might be good for mom & pop, when it comes to gaming...forget it. CPUs get really hot when gaming, especially when air flow is limited. It is unlikely you will be able to get a decent HSF on that AM2 add-in card if you were to upgrade and become plagued with heat issues. Plus, who knows what ASRocks' path is on the add-in board in regards to future AMD CPUs and memory speeds.
I hope this post helps. Please feel free to contact me if you need to.
My current system specs: Asus A8N32SLI-Deluxe, AMD Athlon64 X2 3800+, Thermaltake Tough Power 750 PSU, Thermaltake Big Typhoon HSF, 2 Gig Corsair XMS PC3200 (TWINX2048-3200C2PT), Creative SB-XFi, Plextor 716A DVD Bruner, 2 Segate 7200.9 SATA 2 80G in Raid 0, 1 Western Digital WD1600JS SATA 2 for backup, 1 Western Digital WD3200JD SATA1 in an eSATA enclosure for photo and PVR/video storage, ZBoard Merc keyboard, MS Trackball Explorer, Samsung SyncMaster 204B (Dual Link DVI), and finally; 2, yes two, BFG 7800GT OC in SLI with Zalman VF900-Cu HSFs.
Post by: jkirchman on September 11, 2006, 12:00:06 PM
Thanks for the post Greywolf.  You've given me a bit to think about.  That setup you listed is really nice, however, you are forgetting to add on the cost of a new power supply and a legitimate copy of Windows XP, which is going to add another $110 to your total, which would make it cost almost $700.  Maybe I'll just have to save up for a bit longer in order to get all that you listed.  It is more expensive but probably has better longevity.  I don't know.  They are an endless number of options out there and everyone has a different opinion on what is good and what is not.
One thing I noticed about the motherboard you suggested is that it does not have 3.0 Gb/s SATA capability, which I think is a good thing to have versus the 1.5 Gb/s.
Post by: GreyWolf30 on September 12, 2006, 01:06:03 AM
lol, forgot about the SATA 2. Probably would not notice the difference in most cases. Some of the second gen features might even reduce your performance under certain situations, although probably not anything noticable under light use.
Anyway, here is a different PCIe board to consider:
http://www.newegg.com/Product/Product.asp?Item=N82E16813131530
It will become tougher to find SATA 2 on AGP boards, if you can find the feature at all (the boards like the ASRock you listed are exceptions)
You answered my question on the power supply. One thing to keep in mind is not to go cheap here. Been there, fried that. Seriously. The quality of the PSU will have a large impact on system performance and especially on stability! In addition, it is better to have a higher rating than what you need in your current configuration. This gives you some headroom for additions to your system, such as more hard drives, higher end vid card, etc. As a general recommendation, you should get a PSU with atleast dual (2) 12V+ rails rated for atleast 24 amps total on the 12V+ rails. It should also be designed for Dual Core procs, which usually means you will have an extra 4 pin (square) connector. Stay away from the 4 pin molex to 4 pin square adaptor as you will not get a good flow of power to the CPU. For a single vid card setup, 500 to 600 watts is good. If you want to move to dual cards, things get trickier. You would need 600+ watts with 30 amps or more on the 12V+ rails depending on your setup. (info on my PSU http://www.thermaltakeusa.com/product/Power/ToughPower/W0117/w0117.asp ). The following PSUs are worth considering, especially the coolermaster (if you are willing to shell out the extra dough):
PS Opt #1: http://www.newegg.com/Product/Product.asp?Item=N82E16817154023
PS Opt # 2: http://www.newegg.com/Product/Product.asp?Item=N82E16817171009
As for the OS, I did not include it as there are many variables involved depending on what version you currently have and the type of license involved. At this point in time, if you do not allready have Win2k or XP, you are going to have to move to XP and there are several options for doing it. That is why I treat hardware and the OS as seperate considerations when I research and/or recommend/suggest a build.
In the end, it does fall on how much you can budget and what you are willing to pay for the hardware needed. Gaming rigs will generally be more expensive than non-gaming rigs. Sure, companies like Dell and HP offer "Gaming" PCs around the $1,000 price point, but they are "cheap" in more ways than price. Great if you are on a tight budget and do not want to build your own. Alienware and Falcon Northwest systems start at $1800.00 for specs similar to what we are discussing here. VooDoo PC ( http://www.voodoopc.com/showRoom.aspx?categoryID=1 ), known for their cutting edge and wicked rigs, have starting prices for desktop systems ranging from $2,800 up to $13,600 depending on flavor. For comparason, I have built several complete AMD/NVidia SLi rigs for friends & family in the $1600.00 to $2200.00 range. Sure, the cost we are discussing here is more than Dell's $499 special, but making that comparison would be like comparing $7000.00 in mods to your car with the cost of a Yugo.
I like the satisfaction of having built and/or modified something myself (all PCs in this house are custom builds). Sure, you are more on your own if things end up fubar. However, you not only can choose what you want now, but what you want later instead of being trapped in someone else's idea of what your PC should be.
as an aside; for those that are wondering what I pump my sound out with... I use the Klipsch ProMedia 4.1 system. AND YES, I have gotten imersed in the game, lost track of time and have had neighbors pounding on my door at 2am because they could not sleep due to the gun battle or light sabre fight that seems to be going on right outside their bedroom (despite the large spacing between houses in my neighborhood or solid concrete walls in South FL apartment buildings). Me Bad :grinno:
Post by: jkirchman on September 12, 2006, 01:37:20 PM
I totally agree with you there.  I've had some time to browse and I've revised (read: completely changed) the system I'd like to get.  Here is the new list:
DFI LANPARTY UT nF4 Ultra-D Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard (http://"http://www.newegg.com/product/product.asp?item=N82E16813136152")
BFG Tech BFGR76256GTOCE Geforce 7600GT 256MB GDDR3 PCI Express x16 Video Card (http://"http://www.newegg.com/product/product.asp?item=N82E16814143049")
HIPRO HP-P500W/TOP-500P5 ATX V2.01 500W Power Supply (http://"http://www.newegg.com/product/product.asp?item=N82E16817174023")
AMD Athlon 64 X2 3800+ Manchester 2.0GHz Socket 939 Dual Core Processor (http://"http://www.newegg.com/product/product.asp?item=N82E16819103562")
CORSAIR XMS 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory (http://"http://www.newegg.com/product/product.asp?item=N82E16820145450")
Western Digital Caviar SE WD1200JS 120GB 7200 RPM SATA 3.0Gb/s Hard Drive (http://"http://www.newegg.com/product/product.asp?item=N82E16822144414")
Microsoft Windows XP Home With SP2B 1 Pack (http://"http://www.newegg.com/product/product.asp?item=N82E16832116056")
That whole setup will set me back $708.46 which I think is a good deal considering what I would be getting.  I'm not a super hard core gamer so I think this setup would be adequate and would last me a while.
Opinions?
Post by: Funky Cricket on September 12, 2006, 05:04:00 PM
build it and give it to me?
I have been out of the hardware game for awhile except servers, sounds good to me, but i don't even know what is considered good anymore.
been a good read for me none the less, and I love the amd/nforce combo.
Post by: GreyWolf30 on September 12, 2006, 06:45:09 PM
Looks like a good setup! I have not used DFI, but I hear they are good. The rest I have used, except for the HIPRO PSU. I could not find much that specifically addressed the PSU. However, what I did find seemed ok. While it is not necessarily a good indicator of quiality, I do like that they give a good chart of the circuit capacities on the PSU. That helps in determining what it can and cannot do. It will work for your setup, so long as it works as advertised (which I hope it does!).
WD hard drives tend to run on the hot side, so you may want to look at a cooler of some sort. I use a heatsink with rubber isolators that fits in a 5.25" bay. You can find them at CompUSA for around $10 a set (2 per hard drive). I also have one of these in another PC: http://www.compusa.com/products/product_info.asp?pfp=SEARCH&Ntt=cooling&N=0&Dx=mode+matchall&Nty=1&D=cooling&No=60&Ntk=All&product_code=312439&Pn=Hard_Drive_Cooler
It works quite well and has temperature probes w/ display (if that intersts you).
  What type of case are you using? Does it have places for 80mm and/or larger fans? If you have some open 80mm fan locations, or have old 80mm fans, you might want to pickup some Cooler Master A8025-20CB-5BN-L1 fans to fill/replace. They move a decent amount of air and are quiet.
Other than that, all you have to do is try to enjoy the wait. I really do believe you will like the setup! :grinno:
btw, what games do you normaly play?
Post by: jkirchman on September 12, 2006, 11:51:28 PM
I love the ratings system on Newegg.  Ratings for that PSU are very good and it looks to be a solid unit capable of providing the power I'll need.
I'll be using the same case I have now.  It has an 80mm fan in the side, one in the back, and spaces for others in the front, back, and top.  It is pretty well ventilated now with the fans I have in it, albeit a bit too loud for my taste.  I may look into getting those quieter ones you mentioned.
I normally play simulation/strategy games.  I'm really looking forward to the new Star Trek: Legacy game that is getting ready to be released.  That's actually one of the reasons I've been considering upgrading.  Plus my wife likes to play The Sims and is tired of our current (s...l....o....w) setup of a 1 GHz Athlon and 640MB of RAM.  Yeah...I've allowed myself to get a bit more outdated than I would like.
Post by: GreyWolf30 on September 13, 2006, 01:42:11 PM
The user ratings at NewEgg are usually a reliable indicator of the product, but not in all cases. Based on the reviews, I think you will be fine so long as you do not get a lemon.
You will probably need a few extra fans. Never hurts, plus you can get newer and quiter fans too. Front and side drawing air in, rear and top exhausting.
I have read a bit about the new ST game. Looks pretty good. While I have not been much into RTS, I do get into RPG and FPS/TPS games. Current addictions are: World of Warcraft broken up with healthy amounts of F.E.A.R., sneaking around in Splinter Cell and just blasting away with Half Life 2 and Quake4. :) Every now and then, I thow in some cop action with the older Need for Speed series.
Post by: Funky Cricket on September 13, 2006, 03:24:31 PM
it's all about the 120's
they are quieter move more air, and they just look cool..
i need to update to, hope I can splurge with the tax money for that.
Post by: GreyWolf30 on September 13, 2006, 08:46:01 PM
Quote from: Funky Cricket;103782
hehehe... I got a 120 for you :grinno:
Fan Info: http://www.frozencpu.com/products/2519/fan-22/YS_Tech_120x38mm_Fan_-_125CFM.html?tl=g36c15s60
Sound: http://lib.store.yahoo.net/lib/sidewindercomputers/05YSTech120x38mmFD1212387B-2R.mp3
I got one of these. You DO NOT plug it to the motherboard fan header, you'll kill the board! Most fan controllers can't handle it either. 125CFM BABY!
I used a 60mm Delta Black Label (37cfm - highest flow at that time. Oh, you do not put this one to the mb either, lol)  on an Alpha PAL-6045 Heatsink when I was overclocking back in the day. Had an Athlon 700 running stable at 850 (that's a 22% OC!) on an Abit KT7 Raid.
Sound: http://lib.store.yahoo.net/lib/sidewindercomputers/07Delta60x25mmBlackLabelAFB0612EH.mp3
You won't even notice the fans with your speakers cranked up!
Post by: kingcars on September 14, 2006, 05:40:19 PM
Looks like a solid build; $700-$800 is definately AMD X2 territory (as opposed to Core 2 Duo systems for ~$1000+).  But I would recommend that you get an AM2 setup instead of a socket 939 setup; you'll get more upgradability from it (I hear AM2 stull will support AM3) and DDR2 RAM will give you a slight nose ahead.  7600GTs are great budget cards, but you could get a much stronger, longer lasting 7900GT or 7900GS for ~$200.  No major tweaks needed, though.
Post by: GreyWolf30 on September 15, 2006, 01:19:16 AM
PC upgrading is allways a technology  shoot. New stuff is comming out or being announced regularly. There will allways be the question of waiting or not, getting the mature archetecture or the newest, etc. Like I mentioned earlier, it all depends on what you are going to be doing and what you are willing to buy (within your budget). The only difference between 939 and AM2, aside from the socket, is the memory controller. 939 is DDR, AM2 is DDR2. Sure, DDR2 is twice the bandwidth (4 bits per clock as opposed to 2 bits per clock) and speed, but the latencies are higher and so is the cost. 939 systems are not memory bound when used for general purpose and gaming. They are CPU bound for the most part (depending on the type of chipset used, etc.). I have seen many tests from reliable hardware sites that show this, even when using a top end vid card. Unless a user is into system crushing, bleeding edge chock full of eye candy FPS games (like I am), they are unlikely to hit the limit of their CPU (CPU bound). AM2 will be the same until they up the CPU specs, which I do not see as happening (at least as far as FSB speed is concerned - which would mean a new mainboard anyway). From what I have read in recent weeks, AM2 and AM3 are likely to be incompatable sockets. What AMD is doing is manufacturing a CPU coded K8L sometime early next year. The K8L will run on AM2 while allowing DDR2 or DDR3 memory to be used (not to be confused with GDDR3 memory). I have yet to find 100% confirmation that the sockets for DDR2 and DDR3 will be identical. AM3 is currently expected to be DDR3 only and is scheduled to be released in 2008. By then, you'll be ready to upgrade anyway, especially if you are a gamer. Besides, all that could change depending on how AMD fairs against Intell's upcomming Conroe.
To deepen the mix, SATA drives used on PCI controllers can, and do at times, saturate the PCI bus. This is why you see chip sets with direct northbridge links to SATA ports. While not a gurantee, chances of bus saturation are reduced. Heck, in 2 years, we might see 3rd gen SATA using an on die controler (like AMD's memory controler)!
Then we are off and running on the topic of vid cards. To start, NVidia has been doing R&D on a flip-chip design for GPUs. This means that instead of a big add-in card, you have a socket just like your CPU and the possibility of having it's own memory slots. Think of the possibilities there. Just the thought of FPS and MMORPG games that can take full advantage of a quad core CPU, a boat load of DDR3 memory, a quad core GPU with it's own heap of GDDR3 memory gushing out onto a 32"+ wide screen display is almost enough to give me a woody and land me in Divorce Court! As for vid card choices, the 7900GT or GS are also good choices. However, 2 things will happen. 1) There will be an additional $100 or so for the card. 2) A different PSU will be needed due to how power hungry these cards are. So you can add another $75 to $100. That's really pushing the upgrade over budget (he has allready upped his budget a few bills). To hedge against the possible need for more graphics power, it would be better to get an SLI board. Going with a board like this one: http://www.newegg.com/Product/Product.asp?Item=N82E16813186059 he can still stay within budget. Since the 7600GT cards are not as power hungry (they do not require their own power connector), he can add a second one when they drop to the $75 to $100 range next year and still (quite possibly) use his current choice of PSU while saving him atleast a bill, maybe even a bill and a half!
Post by: jkirchman on September 15, 2006, 12:14:22 PM
My point exactly.  I've let you guys talk me up from $430 to $708.  I will go no higher.  :grinno:
Post by: kingcars on September 16, 2006, 03:22:07 PM
GreyWolf, I definately like the idea of an SLI board so he can get a 2nd 7600GT down the road.  I hear that they're one of the best cards to use in SLI (as fast as a 7900GTX sometimes if my memory serves correctly).
