Technical => Engine Tech => Topic started by: sansabar on August 21, 2006, 10:48:01 AM
Title: More 5.0 HO Upper Swap Questions
Post by: sansabar on August 21, 2006, 10:48:01 AM
A couple of nitpicky things.
One, since the swap I have an intermittent "Check Oil" light coming on.  Never done this before.  I have unplugged and replugged the sending unit and this seems to work.  Any ideas?
Two, where did y'all find the 2 longer replacement bolts? I have looked everywhere and they all stop @ 6 inches.  I found some 7 inch bolts at Lowes, but the threading is too short and seems to bottom out on the spacer.  I currently have the original bolts in there and they grab pretty good, but I would fell better wit hmore threads in there.
Post by: thunderjet302 on August 21, 2006, 03:55:04 PM
I did mine and the check engine light never came on. Are you sure that you plugged all the sensors back in or that the vac lines are all connected the correct way?
On the second point I'm not sure. The spacer I got came with new bolts.
Post by: sansabar on August 21, 2006, 06:01:58 PM
I've checked and double-checked everything.  I found it strange that I could unplug/replug the wire from the sending oil sending unit and it would turn off - almost like a bad ground.  I'll just keep my eye on it. This is the original motor, with 49K original miles. A real find!
I still can't believe that I can't find those long bolts.
Post by: V8Demon on August 22, 2006, 11:49:51 PM
Mine'll chime like crazy if I disconnect it.
Things to check.  The sending unit itself may be bad.  You may be in need of a new battery.  Seriously, run your car with the hood open and have someone give the battery a jiggle and watch what happens.  It makes mine do funky things with an 8 year old battery.
If you have one of the "updated" sending units (the medium sized one) there should be a resistor with it on the wire running to the harness.  Take it out and run the wire straight to the sender.  It'll read higher and won't chime.  I would verify that you have good pressure first.
The picture below shows the resistor with the sending unit on the right.  The big unit on the left was replaced by this setup on full digital dashes.  If you have a base cluster with the small sending unit I'm unsure if you have the resistor.
Post by: sansabar on August 23, 2006, 07:13:33 AM
It hasn't happened in a couple of days now. Thanks for the tips.  I seem to remember having the smaller unit with the resistor - I have a full digital dash.
Any idea where I can find the 2 longer upper intake bolts?
Post by: Haystack on August 23, 2006, 07:26:24 AM
I have found them at local hardware stores...
Post by: jkirchman on August 23, 2006, 11:12:38 AM
Wait a second.  You said that the "Check Oil" light was coming on, right?  Are you talking about the red light in the upper right corner of the instrument cluster?  If so, the oil level sensor is responsible for that.  That sensor is located in the oil pan itself.  You can see it plugged into the driver's side of the pan if you look under the car.  It may just need replacement.  It usually makes the light come on if the oil is one quart low or more.
Post by: sansabar on August 24, 2006, 05:46:07 AM
Quote from: jkirchman
Thanks.  That's the beast.  I'll be checking that this evening.
Post by: thunderjet302 on August 24, 2006, 03:58:29 PM
If you drip some oil on the low oil level sensor it'll stay on as well. Make sure the wires and the sensor are clean as well. Uh don't ask why I know this;)
Post by: Kitz Kat on August 25, 2006, 03:30:43 PM
Where can you get that resistor,thats the 1sst I heard of that.
Post by: V8Demon on August 26, 2006, 07:40:03 AM
Basically any Ford product with a full digital dash and a 5.0 had them after 87 (I believe they made the switch from the larger sending unit sometime in the middle of the 87 model year) .....Cougar, T-bird, Mark VII, Town Car, etc.  I have a couple of spares from the junkyard that are in working order and have been tested in my car.
Post by: thunderjet302 on August 26, 2006, 03:29:22 PM
So is the big sending unit more accurate than the small one with the resistor that I have?
Post by: quicksilver on August 26, 2006, 05:01:15 PM
how much will ported E7TE with 1.6 roller rockers add over stock heads? and how much will the HO cam over stock cam?
and does the computer add any horsepower?
