Technical => Body/Appearance/Interior => Topic started by: Nate on August 06, 2006, 08:26:13 PM
Title: hood spring removal
Post by: Nate on August 06, 2006, 08:26:13 PM
anybody know how to safely remove the springs on the 87-88 hoods? it looks like maybe pry the one part up over the part its resting on and slide it off, but i dont want it flinging off and braking anything, or myself.
Post by: Innes on August 06, 2006, 08:37:35 PM
Collapse it after hood is off then wire tie it closed/shut then remove. It’s been a couple of years I think that’s what I did. Oyea when ting down be very very careful til its wired tied it could pop up and seriously injure you.
Post by: 88turbo on August 06, 2006, 08:58:32 PM
heat it with a torch when its streached and it should stay in that position.
Post by: Vantage08 on August 07, 2006, 12:31:45 AM
We found another set, cut the springs off teh other set, then just removed the origional set from the hood(for my cowl hood).
Post by: 87badbird2613 on August 07, 2006, 03:03:18 AM
nate i can show u on tuesday
Post by: 88turbo on August 07, 2006, 06:59:51 AM
anyways why remove them?  I thought they were better than having a prop rod in the way, but maybe you guys think differently.
Post by: TurboCoupe50 on August 07, 2006, 09:09:47 AM
Quote from: 88turbo
Not on a fiberglass hood...
Post by: Vantage08 on August 07, 2006, 11:49:30 AM
They break a fiberglass hoods, mine was starting to crack under neath and the top was showing creases =:/ but for reg hoods their good.
Post by: Tbird232ci on August 07, 2006, 09:02:48 PM
Pick up some 84-85 hood hinges
Post by: 87badbird2613 on August 08, 2006, 12:33:03 AM
i use them on my fiberglass hood  you just have to undo the little square clip and then you can move it up and down freely and use the arm as a hood prop
Post by: wyoming_bird on August 08, 2006, 10:29:49 AM
I have a set of red un-sprung hinges that I took off of my Bird when I put on the sprung hinges I got from a junk yard.  If you want them I can ship them to you.  I think that just changing the entire hinge assembly would be much easier than trying to remove the spring.
