(http://f10.putfile.com/thumb/8/21509161555.jpg) (http://putfile.com/pic.php?pic=main/8/21509161555.jpg&s=f10)
(http://f10.putfile.com/thumb/8/21509155948.jpg) (http://putfile.com/pic.php?pic=main/8/21509155948.jpg&s=f10)
(http://f10.putfile.com/thumb/8/21509154375.jpg) (http://putfile.com/pic.php?pic=main/8/21509154375.jpg&s=f10)
Not every thing is what it appears to be. I snapped these because it makes it look as if I'm hiding a roots supercharger under the tarp.
Oh you rotten getting me all excited for this.
Well I started the car tonight. Started right off after I got everything put back together. I ran out of day light so no pics yet. Plus I still have some small things to finish up. Like the electric fan.
I found out there is alot of room under the hood of these cars after you remove the smog pump and all the lines.
That's one shagy 300 hp bag you got under the hood;)
I know!!!
No I took the pics becasue it made it look like it had a roots super charger.
I will have new pics later. But I dought it is 300hp yet.
I know I'm just messing with ya ;)
Well its all together now.
Cool.I remember how good it felt to get the H.O. installed last year.It's been great.I noticed you have a Cobra intake.Good piece.I have a polished Explorer intake.They flow about the same.I noticed an increase in the torque in the higher rpm's with it.Nice work you've done.I can't tell be the pics.Are you running factory headers?Keep us posted on the progress.
Funny it still has the SO bottom end right now. Yup still has the mustang factory header. I do have a set of Headman long tube that need installed still.
Cobra intake with a 70mm BBK TB, and 70mm Air meter. I'm having problem with it idleing and running. I have afew things to check still fuel pressure, and coil.
Looks good:cool: . Is your TPS set to .98 volts? That might help solve your problem.
It spits and sputter and back fires so I still have some things to work out.
Ah more than setting the TPS. Have fun fixing it. I hope it's something easy.
TB is too big :( 60mm would run better...
Looks like I need to change the fuel pump and regulater. I'm only getting about 20psi of fuel at all times.
Anyone know what I'm supposed to have?
don't quote me on this but i think its around 36 psi.
40
37-39 stock
