Technical => Drivetrain Tech => Topic started by: CougarBaby on December 21, 2004, 01:55:42 AM
Title: DriveShaft question for an MN12
Post by: CougarBaby on December 21, 2004, 01:55:42 AM
ok, i donno if i'm in the right place, if not, oops....and so far i didn't come across any driveshaft threads...Unless I'm blind and didn't see it, but guess what?...
I have a 96 DriveShaft, that my friend gave to me from his tbird and it's in the back of my closet and I wanted to know if It'll fit my 89 baby.  If so, will i feel any differnce ?, well she run better? etc...
Danke!...(thanks in german)
Title: Re: DriveShaft question for an MN12
Post by: lowcat on December 21, 2004, 10:39:57 AM
Unless there is something wrong with the driveshaft currently on the car I don't believe it would make any difference.
Post by: EricCoolCats on December 21, 2004, 11:03:09 AM
Depends on the length...the later cars had different transmissions and may have had different tailshaft lengths.
Post by: jcassity on December 23, 2004, 08:13:17 PM
Oh and btw , just to add to the drive shaft info.
i actually found this approved maint step in my FoMoCo manual for troubleshooting a drive shaft with vibration.
mark the drive shaft at the 12,3,6,9 o'clock positions.
install a hose clamp and tighten so the adjuster is at the 12 pos.
drive car
position hose clamp in different positions until the vibration is nominal.
Tighten clamp and locktight the adjuster
i guess that  adjuster acts as a counter balance. I tried it on my wifes bronco and it really does do some crazy stuff to the vibration.
Post by: zpyro on December 24, 2004, 03:21:51 AM
where on the driveshaft should it be? like close to the tranny, close to the rear, ?
Post by: jcassity on December 24, 2004, 08:54:35 AM
Quote from: zpyro
position it anywhere you want to start with.  you will eventually hit the sweet spot.  thats what the book says to do for the most part, its a guessing game.
most people need to replace the tailshaft bushing instead to take up slop from a vibrating driveshaft.
sorry cougarbaby,, this is your thread.
Post by: Sancho on December 24, 2004, 03:48:41 PM
If its aluminium there will be a improvement in gas mileage and possibly acceleration ( I didn't notice any)
