Computers/PCs => General Computer Forum => Topic started by: stuntmannick on July 24, 2006, 12:56:18 AM
Title: Blue Screen of death
Post by: stuntmannick on July 24, 2006, 12:56:18 AM
Ok, so we have a newer desktop Sony Vaio.  I don't use the computer, so I don't know what was changed or screwed up, but when I turn on the thing, windows starts to load and then this screen comes up saying that there is an error in software or hardware that won't allow it to boot.  I tried messing with everything in the bios, tried to boot in safe mode, keep getting this screen.
After the first couple of sentences it says: UNMOUNTABLE_BOOT_VOLUME
At the bottom of the screen it says
TECHNICAL INFORMATION:
***STOP:  0X000000ED  (0X863577B8, 0X0000006, 0X00000000, 0X00000000)
The recovery discs are nowhere to be found.  Any help would be appreciated.
Post by: stuntmannick on July 24, 2006, 01:02:08 AM
nevermind for now, I'm going to try the second method in this (http://"http://www.windowsreinstall.com/install/winxp/howto3/unmountable.htm") link
Post by: nirvanagod on July 24, 2006, 08:29:03 AM
http://support.microsoft.com/kb/297185/en-us
Thats about the jist of it, if you have a Windows XP cd (I pressume that's what you're running), run the chkdsk /f/r command from the recovery console command line.
Post by: Funky Cricket on August 12, 2006, 11:03:48 AM
the master boot record is hosed, it see's the drive as bootable but can't mount the file directory.
as mentioned, run the chkdsk/f/r from recovery console then also try running fixmbr after that.
