General => General Fox T-Bird/Cougar Discussion => Topic started by: 86Tbuzzard on July 21, 2006, 08:26:08 PM
Title: 3.8 SC in a Fox tbird/cougar
Post by: 86Tbuzzard on July 21, 2006, 08:26:08 PM
has anyone done it? think it'd be pretty fast seeing the fox body weighs less than the MN12...been think out doing one up then selling it.
Post by: 84 Fila on July 21, 2006, 09:03:02 PM
Worth a try. Just gut a Super Coupe and transplant???
Post by: CougarSE on July 21, 2006, 09:13:09 PM
see sig
Post by: Thunder Chicken on July 21, 2006, 09:30:12 PM
Quote from: CougarSE
see sig
Um, that's new, isn't it? :bowdown:
Spazpuppies did it as well...
Post by: ipsd on July 21, 2006, 10:37:30 PM
Anyone know if the super charger setup will bolt onto the 88 3.8 motor. I have a line on one but the motor is toast. But the whole deal with computer for $550.
Post by: Chuck W on July 21, 2006, 10:41:03 PM
It'll probably bolt on...but just like bolting a turbo onto an NA 2.3....BOOM!  At least eventually.....
Post by: CougarCoupe88 on July 21, 2006, 10:52:06 PM
everything supercoupe is different internally inside the engine. the only thing that may be the same is the block. but im not 100% sure.
i know the 5speed wouldnt work in a fox unless you put a t-5 behind it. and the aod would take all the fun out of the swap if you ask me. then their is getting it to run . and well at that. it can be done. it has been done does have the Really cool afect. but the souper coupe was that a super coupe with the luxury of a big car but the ride of a sports car. fully indipendent suspention. those cars rock so much. but i like the 94ish ones best that nose is oh so shagy
good luck
Post by: 84 Fila on July 21, 2006, 10:54:33 PM
Is it realy worth the work and eventual heartake of doing the swap? just curious?
Post by: ipsd on July 21, 2006, 11:02:41 PM
I understand that the internals are different such as forged pistions. But what else would be different besides the grind of the cam and maybe some hardened valves.  Also as in the 2.3t you can use a full na motor you just need to watch closely for detonation, due to the ease to mess up the non-forged pistions. So what else would be different. The bottom end in the other one is knocking bad. I have a good running 88 3.8 but the car is toast. Just wondering for that reason.
Post by: jkirchman on July 22, 2006, 09:44:44 AM
Kind of.  Ever driven an automatic SC?  I had a '90 XR7 that I drove for a little more than a year.  It was a blast to drive, even though it wasn't a five speed.
Pretty much everything is different.  You would implode an NA 3.8 if you put that Eaton blower on it.
Post by: CougarSE on July 22, 2006, 10:44:29 AM
The block is different, its stamped on the back "SC".
The heads are differen't, there stamped in the corner "SC".
The crank, rods and pistons are all forged to handle the boost.
N/A 3.8's can handle about 5 psi on a good tune.
You cannot even put SC heads on a N/A block, the oil drainback and water holes are different.
*Psst*  The swap isn't actually done yet on my car.  Still waiting on a few things.  But i've got it down to every last wire that has to be changed and every last bolt that has to be turned.
Post by: Thunder Chicken on July 22, 2006, 11:27:15 AM
Hell, N/A 3.8's can hardly even handle atmospheric pressure, let alone boost. If the head gaskets are pr0ne to failure on an N/A engine, imagine putting a supercharger on an N/A engine...
Post by: V8Demon on July 22, 2006, 12:01:44 PM
Pics of Spaz's car are in the thread below.  They still work.
http://www.foxtbirdcougarforums.com/showthread.php?t=1868
Post by: CougarSE on July 22, 2006, 12:03:22 PM
Quote from: Thunder Chicken
Very true, but many a dumbass has boosted a stock block.. I even contemplated it myself.
Post by: Spaz02 on July 22, 2006, 02:51:52 PM
I think I remember reading about someone on tccoa putting the supercharger on the stock block and reducing the amount of boost so he would not destroy the engine.  I don't think it should be done but hey go for it if you want just don't be surprised if you destory your engine.  Also I would reccommend changing that tranny cuz mine didn't last too long and was replaced with a rebuilt lsc tranny with shift kit.  Despite mine not being a 5 speed, it's still one hell of a car to drive.  CougarSE I had just seen your post the other day over at sccoa, I didn't even no you were attempting to do it.  How long you been on the project? You think you'll have it done this summer?
Post by: MexCougar on July 22, 2006, 03:18:23 PM
Hahahaha, Claude, i was searching where in the forums you put that SC engine into the Cat, but i know this is a project. This time, take a LOT OF PICS and do a LOT OF DRAWINGS AND DIAGRAMS. The SC swap still is a mystery for the 99.98% of the people here....
Post by: CougarSE on July 22, 2006, 04:34:06 PM
Before putting the engine back together I'll have the heads ported.  Got a guy in florida for that.
I have alot of information gathered already but not enough of it is together and pretty like the 5 speed swap thread.
When I feal frisky I'll start to compile it all together.
Post by: Haystack on July 23, 2006, 12:26:38 PM
do the 89 up sc's have internal balancing?
Post by: CougarSE on July 23, 2006, 11:11:01 PM
As in a balance shaft?
No, only 88's came with the balance shaft.  But every 3.8 block from 88 on is machined for the balance shaft.
Post by: blu84302 on July 24, 2006, 07:42:54 AM
Claude, did you get the parts from Lance or something?  Don't tell me you got it from pick'n pull.  I'm so jealous right now you have no idea!...  Now i gotta go get a 351w for the bird to keep up with you're crazy ass!  Not to mention I got beat by a focus the other day.  Do you know how that makes me feel?  I feel slow and hopeless.
if anyone can do the swap you can claude,  i've known you for awhile now and you're awesome at moddin.  So keep up the good work and if you need help just let me know!
Post by: CougarSE on July 24, 2006, 10:16:17 AM
Thanks John!
And I would lose to a focus too, but then again I only lost too you when I had an auto and py gears!  REmatch!
Post by: Haystack on July 25, 2006, 08:07:17 PM
I am looking into swapping a 88 block into a 87 cougar, and I was curious about the sc as well as mateing a stick to it. But I will not be able to until I have more time and money. Good luck, I will be looking forward to this.
