Technical => Electrical Tech => Topic started by: FLYN83BIRD on July 09, 2006, 11:13:04 PM
Title: ?'s on the stock computer.
Post by: FLYN83BIRD on July 09, 2006, 11:13:04 PM
My car is an 83 Heritage 302 T-Bird with I beleive the CFI injection.  and I want to put a cam and intake and carb on it.  What else will I have to change.  Better yet what does that computer really do.  I know that I have to get a fuel regulator because of the carb.  I also want to put an MSD 6A that I have laying around in it.  Please help me out and give me some feedback.  Thank You.
Post by: TurboCoupe50 on July 10, 2006, 10:01:00 AM
The computer operates the CFI fuel injection, AFIK thats all it does... There are no parts to upgrade the EEC-III system... A carb or later system would be your choices..
Post by: softtouch on July 10, 2006, 04:35:02 PM
The EEC-III also controls the ignition. Does the MSD 6a replace more than the ignition module? If not you will need a distributor. Your current distributor has no stator or PIP pick-up in it. The EEC-III uses a crankshaft position sensor.
The EEC may also control the fuel pump, not sure though.
Post by: FLYN83BIRD on July 10, 2006, 08:53:10 PM
I was pretty sure that it ran the py CFI and I do beleive fuel also.  It's nice to get a second opinion that kind of stuff.  I thank you all for your input.  Things to buy- Distributor, Intake, Carb.  And wire up the pump to a switch or keyed source and a regulator.  Thanks again for everything.
Post by: TurboCoupe50 on July 10, 2006, 10:29:44 PM
When I said the fuel injection, that includes the electric pump as it is part of the total package...
Post by: FLYN83BIRD on July 11, 2006, 07:09:16 PM
Quote from: TurboCoupe50
Yeah, so I can run wires to the pump and hook them up or buy a holley blue pump and run braided line all the way up to the regulator and so forth.
Post by: jcassity on July 12, 2006, 02:49:29 AM
leave the EEC, it will provide power to the fuel pump for you , then add your regulator as required in the engine bay.
Next up, i would use a points distributor and your existing coil.
The EECIII system and knowledge about it is very hard to come by,, here is a link to someone else asking questions as well,,,,,,,http://www.ford-trucks.com/forums/archive/index.php/t-243403-1982%20EEC%20III%20loses%20spark
might help you get going.  Google EECIII
think that would be it, sorry if i missed anything.  Careful on the size carb,, not too big now:D
Post by: TurboCoupe50 on July 12, 2006, 09:53:20 AM
I'm not real knowledgeable about the III system, but Im fairly sure without the sensor inputs(specifically the Crankshaft sensor)the fuel pump circuit won't operate.
