Technical => Engine Tech => Topic started by: kewlbird08 on July 05, 2006, 09:15:17 PM
Title: What to do... What to do?...
Post by: kewlbird08 on July 05, 2006, 09:15:17 PM
Well I decided to wait another year to drop in the 351.  SO, I have some 'new found' cash to work with.  What do you guys think I should do?  2.3L Turbo Coupe, Boost Valve, 5-Speed, Wheels/Tires.  Previous owner got a cheapy exhaust job done, I'm not even runnin' dual exhaust at the present time.  I was thinking I should just run 3 inch dual exhaust all the way back with flowmasters and then just keep it for the 351.  What does everyone think?
Post by: Tbird232ci on July 06, 2006, 06:04:56 PM
Quote from: kewlbird08
3" dual wont fit.
Post by: DVP on July 06, 2006, 06:27:43 PM
were doesnt it fit? i was thinking of doing 3" but whats the problem? i know you can run a single 3".
Post by: tbirdscott on July 06, 2006, 08:41:57 PM
Give it to me.
Post by: Tbird232ci on July 06, 2006, 08:51:51 PM
Quote from: cougar86_89
Around the passanger side of the car entirely. Especially over the axle and around the gas tank.
Post by: kewlbird08 on July 07, 2006, 01:50:37 PM
Will 2.5" fit?  And will i lose too much back pressure with 2.5 duals?
Post by: TurboCoupe50 on July 07, 2006, 02:16:52 PM
With minor adjustments(IE large hammer) to the gas tank support brackets, 2 1/2" fits fine....
Stop worring about back pressure... ANY amount is BAD... IF you loose performance with improved exaust, it's time to richen the mixture...
