I was at the car retirement center(junk yard) and was under a 89 towncar and noticed that the trans has a drain plug on it.It has a AOD and a 5.0.It looks like an easy swap.This would be a great on my bird.I would change the fluid more often.
Will it work?
I'm pretty sure the Lincolns got a longer transmission than our T-birds and Cougars. Someone else can verify this, I think.
Go to an auto parts store and buy a drain plug for like $2 and install it in your existing pan, probabally easier and you probabally need to change the gasket/filter anyway :p
D'oh! I thought you were talking about the whole tranny! Disregard what I said.
FRPP sells a chrome plated AOD trans pans with a drain plug. It was under $40 last I remember.
To answer the question, yes all AOD pans use the same bolt pattern should work no problem...
