Technical => Misc Tech => Topic started by: 88turbo on June 21, 2006, 09:43:27 PM
Title: How do you pull codes?
Post by: 88turbo on June 21, 2006, 09:43:27 PM
since there isnt a thread dedicated to this can someone take alittle time to type out how to do this?
Post by: MasterBlaster on June 22, 2006, 09:23:12 AM
Here's my recent post from: http://www.foxtbirdcougarforums.com/showthread.php?t=8668 (http://"http://www.foxtbirdcougarforums.com/showthread.php?t=8668")
[COLOR="Red"]Just count along with the flashes.
When there's a short pause where a flash should have been, write down the number you just had.
When there's a huge pause, wait for the single flash that separates the "KOEO" (current problem) codes from the "continuous memory" (previous problems) codes.
The codes in each section will be repeated twice. Here's code 32 KOEO, and 21 "memory".
And here's the picture I usually point at: . (http://www3.telus.net/neat/eec4.gif)
Post by: 88turbo on July 22, 2006, 10:13:53 PM
heres what I came up with....
23-tp sensor out of range, 26-VAF sensor input out of self-test range, 34-insufficient EGR flow, 42-EGO/HEGO switching detected, system rich, 74?, 67-Neutral drive switch open. A/C input high
how would I begine to track some of these down?
Post by: 88turbo on July 23, 2006, 02:51:39 PM
Post by: JeremyB on July 23, 2006, 04:04:38 PM
KOEO, or KOER? What about CM?
Post by: 88turbo on July 23, 2006, 05:54:51 PM
uh........ koeo key on engine off? koer key on engine running? CM?
Post by: JeremyB on July 23, 2006, 06:20:31 PM
So, are your codes from a KOEO, or KOER, and what about CM codes?
Post by: 88turbo on July 23, 2006, 08:05:28 PM
Koeo not sure how to pull CM codes
Post by: softtouch on July 23, 2006, 09:34:40 PM
Reread Masterblaster's post. Also read the thread he linked to.
The 67 may be because you had the A/C on when you ran the test. All electrical stuff radio, A/C, blower etc must be off when you run tests.
Post by: 88turbo on October 03, 2006, 01:42:41 PM
sticky worthy?
Post by: Beau on October 03, 2006, 02:07:02 PM
I second the sticky.. Also, (and this should be common sense) make sure that whatever source you use for codes is accurate. My truck apparently had an O2 sensor bad according to the code i was getting, and a known good sensor did not fix it...turns out it was the EGR position sensor bad, I replaced it, and all is well now.
One other thing, after repairs have been made, make sure to unhook the battery, and pull the headlight switch on, or ground the positive battery cabe a time or two, to "purge" electricity from relays, etc, to allow the computer to "relearn" the sensors without having bad readings.
Now..if I can track down that able electrical drain in the truck... :beatyoass:
Post by: turbopete on October 05, 2006, 07:57:28 PM
34 is a normal code for an 87-88 that has had the EGR recall perfomed. If it has a little round black and green check valve in the vacuume line to the EGR valve, it has had the recall performed. Turbo Coupes don't have an EGR position sensor.
67 - you probably had the AC on when running the codes, as others have noted
42 - the 02 read rich for more than 15 seconds. Good chance that the problem IS NOT the 02 itself. Find out why the engine is running rich and fix that. Look at the TPS code and the VAF code. Something isn't right there. Run the KOER tests and see if you get a 42 there
74, you didn't step on the rake pedal at the appropritate time to operate the BOO (brake on/off switch)
CM (continous memory codes) are outputed after the KOEO codes This article will give you an overview of pulling codes; http://www.turbotbird.com/techinfo/RetrievingCodes/retrieving_eec_diagnostic_codes.htm
Post by: jcassity on November 02, 2006, 02:22:15 AM
Quote from: FordTruckFreeek;106707
you cant clear codes or anything by doing that. you have to unhook your jumper wire while codes are being dumped out in order to clear recent codes. the cm codes cant be cleared until 40 warm up cycles has been reached ,so they say (the manual that is)
on your trunk drain,, i discovered a while a go on my coug the the sockets aged over the years of getting hot and so forth that the bulbs actually can be plugged in backwards. worth checkign into if you check out your tail light opperation one evening.
