Is it possible to use a turbo on more then one size engine? Kind of like would it be possible to take the turbo itself off a 4 cyl and stick it on an 8 or is there something keeping it from being done?
I know you would have to put an exhaust for a turbo on it. But with the turbo itself would it do what its supposed to and make more power?
If its 4 cylinder specific for the turbo could you put 2 of them on a V8 and run twin turbos? after all they would still only have to put up with 4 cylinders that way right?
Im totally clueless on turbo other then I know they make noise when they start working.
I'm pretty sure a single turbo from a 2.3 would be too small to do any work on a 5.0, but 2 of them would probably work well. You could also use a single, bigger turbo on the 5.0. Shawn and/or David probably has more infor on this.
well I was just thinking because Ive seen exhaust kits on ebay for twin turbos and such. That and a few turbos on there for pretty cheap got me to wondering.
Shawn showed me a pic a while ago of a guy who had a Mustang TT setup that looked mostly home-made and it was pretty cheap to put together, too.
yeah I found a set thats ready to bolt on for like 1700 bucks thats a little more then I can spend .
I was just trying to find a cheap way of doing it
