Marketplace => T-Bird/Cougar Parts & Cars FOR SALE => Topic started by: the_intimidator03 on June 12, 2006, 08:30:08 AM
Title: 84 cougar 3.8 engine/trans parts
Post by: the_intimidator03 on June 12, 2006, 08:30:08 AM
Ok.... ill be pulling the engine/trans out of my cougar hopefully within the month.  was curious if anyone needed parts? its got a rod knock and burns oil... could be valve seals or rings not sure yet.. but intake/ heads etc are up for grabs... also the C5 transmission worked fine but i think i had issues with the kick down rod on it other than that its in good shape and id let it go for 50 obo plus shipping.... i am in southwestern oregon (roseburg) i may have some other things like 2.73 rear end gear/pinion 7.5 inch rear... just seeing if anyone needs these parts before they get put into another car for s weight..  Let me know there is plenty of time
  Sincerely
            Eric
Post by: Haystack on June 12, 2006, 01:40:57 PM
Hey I need a timing chain cover, and all the bolts used to get it off. I had all of my bolts sitting in a bucket last winter, and my little brother dumped out the timing chain cover and bolts. Now I am not able to find most of the bolts. So if you could get me the timing chain cover, and all bolts to all the front acessories, it would be apreciated.
Post by: the_intimidator03 on June 12, 2006, 04:43:09 PM
I can do that. it has the in tank pump so it doesnt have mech fuel pump provisions....... as soon as i can get the car down to where it needs to be n pull the engine the timing chain cover and bolts are YOURS.  shoot an offer and im sure it will be accepted lol
