Will a mark 7 aod shifter fit in a 86 t bird? If not, will any others work?
No the mark shifter will not fit in the bird.
Although if you want to make it work anything can be done with alot of custom fabrication.
I put a stang slash TC modded shifter in my car due to the floor shift and stang aod.
The MK VII uses a cable type shifter that runs through the floor... It can be used but you'll have to fab up some sort of surround as its a ugly piece.
What about a tturbo xr7 with a c5?
Commom, what else are you guys useing?
