Technical => Suspension/Steering => Topic started by: Shevretti on May 30, 2006, 05:54:17 PM
Title: Front right suspention patter...
Post by: Shevretti on May 30, 2006, 05:54:17 PM
Hi there!
My T-bird is making that patter noise from the day I got it. It only happens when I'm driving on eg. gravel/coutry style roads. It's a strange sound like a rubber hammer hitting floor.
It's a Spring time, so I've decided to check what it may be and replace the defective part of suspention. I suspect it may be a shock absorber or ball joint? The shocks are OK, but I heard Gabriel shocks are known for making a noise like that.
If it's a shock absorber, which struts do you reccomend for daily driven 3.8 T-bird with stock suspention and "baloon" 215/70R14 tires?
Take care!
P.S. Hope you will like the new photo in my signature :)
Post by: CougarSE on June 02, 2006, 12:34:42 AM
I dunno about 10" brake cars but 11" brakes are bad about the calipers rattling.  Mine does it.  Sounds like something is loose under the car.
Try this.  when you hear the rattling noise.  keep your foot on the gas (petrol?) pedal and very lightly press the brake pedal.. If I do this my noise goes away.  I don't know what to do to fix it.
Post by: thunderjet302 on June 02, 2006, 12:12:20 PM
How are your front sway bar bushings and endlinks? If the rubber is going bad that could cause the bar to shift around a bit and cause that noise. Also if you do change them polyurithane is much better than the rubber and stiffens up the front a bit.
Post by: ipsd on June 03, 2006, 04:06:57 PM
Have you checked your ball joints? could make a really bad noise when the are out. They are kinda hard to check but do a search we have talked about many times.Cougar Se  Are you sure its caliper rattle and not brake pads? Make shure you install shims if they aren't built onto the pad. Then another thing would be to use some brake squeek greese. It's kinda like gule to hold the pads to the caliper. Last if not least install new pins and those pesky little rubber boot things they slide into.
Post by: Red_LX on June 04, 2006, 02:25:47 PM
Hey Shevretti, my car makes a similar noise from the driver's side front wheel, along with a constant squeaking while going over bumps. I checked the ball joints, bearings, etc and everything is good. Basically I've narrowed it down to the broken spring on the driver's side (has about half a coil broken off the bottom)...it has to be the thing making all the noise because I can't find anything else that it could be!
Post by: 85turbotbird on June 06, 2006, 01:20:56 AM
Mine makes a noise like that but only when I've got 2+ in my car.  I know I need taller springs due to my taller tires I threw on. Also, my rear control arm bushings are shot, my endlinks are junk and etc.  I'd def. look at the endlinks and balljoints
Post by: Sick88Tbird on June 07, 2006, 08:42:22 PM
I used to get a similar noise from my right front suspension, but only when I had a passenger in the car...it eventually got worse...my struts were cooked...but i also replaced the ball joints(which didn't look too bad), tie rod ends, steering rack and I did the 11" brake upgrade.
Post by: Shevretti on June 09, 2006, 03:49:04 AM
Thanks for all your ideas! I've already replaced the sway bar bushings and endlinks. Checked the brakes and lubricated everything well. The springs are one piece too. Think I should check the struts and ball joints. What about the strut mouts?
Post by: Chris1987LX on June 09, 2006, 11:38:38 AM
The strut mount may have failed which would cause some rattle and noise.  Good idea!
Chris
Post by: Red_LX on June 09, 2006, 12:15:46 PM
Hm, I may have to check my strut mounts aswell...
Title: F/end ??
Post by: leblumax on July 07, 2006, 04:54:26 AM
My 88 T-Bird Sport Rack + Pinion broke a couple weeks ago. Luckily I was going 20 in town not 70 on the freeway. Had it towed to a dealer and was told I also need balljoints (lower/outer) and steering column bearings. I told them to hold off on the BJ's because I have had them checked twice recently and was told they are fine (not checked by them). They couldn't get the steering column bearings either, not new or junk yard.
After I got it back I took it to a mech I trust and he said the BJ + Steering Bearing are fine. I filed a BBB complaint because they were trying to push $1000 worth of repair that I might not need. Now they are pestering me to bring it in and let them prove to me how "dangerous" the BJ's are getting. They say to check them requires "a special procedure". Are they bull pin' me or what?
I do get a little "wobble" (real little) once in a while from the F/end and at highway speed there is a thump thump that feels like a tire out of round/balance. Could that be the BJ's??
