Technical => Engine Tech => Topic started by: 87fordboy on May 13, 2006, 09:57:39 AM
Title: spark plugs
Post by: 87fordboy on May 13, 2006, 09:57:39 AM
how did u guys get your sparks plugs installed easily? cuz on mine they are in such a tight spot.
Title: spark plugs
Post by: the_intimidator03 on May 13, 2006, 10:48:41 AM
You can run flex heads those would help.... just finger start ur spark plugs and use anti seize on them.  or... u can cut holes in the fender n do it :-D lol just my 2 cents
    Eric
Title: spark plugs
Post by: Tbird232ci on May 13, 2006, 10:58:34 AM
Theyre a total pain in the arse on a 3.8L. I lost some tools because of my temper.
Im fixing the solution by putting a 5.0 in it.
Title: spark plugs
Post by: V8Demon on May 13, 2006, 03:30:39 PM
Even the motor swap is easier than gettin to that rear passenger plug on a 3.8.....
