Computers/PCs => General Computer Forum => Topic started by: Ifixyawata on April 21, 2006, 04:25:01 PM
Title: Diagnosing ANOTHER No-POST situation...
Post by: Ifixyawata on April 21, 2006, 04:25:01 PM
Only this time it's my own computer...
I got an email from newegg.com and they were having a sale on a Lite-On DVD burner with Lightscribe for only $40 so I had to have one.  Anyway, it, along with a new keyboard, get here today.
Went along with installing it, took out the old CD-RW drive and put it in place next to my other DVD-RW drive (yes, dual DVD burners is excessive.)  While I was in my computer I noticed that it looked like about a years worth of dust had accummulated in only 4 months time.  So, I proceeded to spray out  the innards with a can of "duster".  It all went well except when I inadvertantly turned the can on its side and it blew that freezing cold liquid into the still-warm power supply.
I thought nothing of it until I tried to reboot and I got noting.  No beep codes, no post, not even any output to the monitor.  After pulling the plugs on the new drive first, then pulling a few other plugs and trying to at least produce a beep code, I got nothing.  Even pulled the RAM out.
Next I tried 2 other power supplies and they both produced the same results. I even threw in a separate hard drive and got nothing.
So, the story is, I get a power light, drives spin up, all the fans come on, including the CPU, chipset, case and VGA fans.  Power and reset switches seem to be working.  However, I get no beeps.  I've sort of ruled out the PS because nothing changed when I swapped 2 others in.  I don't think it's the drive because you can't even hear the arm moving around in there.
I'm open to suggestions, but I'm thinking I probably have a toasted MB (or maybe a PS?).  Any guidance is greatly appreciated.
Post by: 4thqtr on April 21, 2006, 08:35:28 PM
Taking a wild (probably off-target) shot here - is the MB battery dead? Do computers these days even depend on them anymore? I haven't been into computers since I built mine like 8 years ago. I want some oatmeal.
Post by: nirvanagod on April 21, 2006, 09:57:00 PM
Set the jumper on the motherboard to reset the bios to default, hit the power button once, then (it shouldn't power on) put the jumper back. See what happens, then post your results.
Post by: Ifixyawata on April 21, 2006, 11:51:33 PM
Let me go dig up a PDF of the manual so I can find the jumper for that and I'll post back as soon as I can.
Post by: Ifixyawata on April 22, 2006, 01:09:05 AM
Ok, the BIOS trick worked to get the computer POSTing again.  Now, however, it seems to hang when it gets to a certain point.  That point is:
During a regular boot- about 1/4 of the way through the Win2k progress bar.
During a Safe Mode boot- at the file mup.sys (I'm thinking of trying to replace that file.)
During a new Win2k Install- Once the blue status bar at the bottom says (Starting Windows 2000).
I can't figure out why it's going so far then hanging.  Doesn't seem like it would be a heat issue, because if it was, it wouldn't be so consistent.
Where do I go next?
EDIT- Update:
Ok, so I did a search on Google of MUP.sys and came up with a few possible solutions including; disabling various BIOS features, removing all USB and/or PCI devices.  I tried and none of these yielded results.
Could this mobo/CPU really be trashed after only 4 months of use?!?
At this point I'm ready to go further into debt on a new Mobo, CPU and RAM and call it done.
Post by: MasterBlaster on April 22, 2006, 10:07:29 AM
Special computer-innards-safe spray, or a generic static-out-the-ying-yang spray?
Liquid? Inside a computer?????  :nono:
Post by: Ifixyawata on April 22, 2006, 10:55:42 AM
I honestly forget what the name of the product was, but it was designed for the inside of computers, electronics, etc.
Post by: nirvanagod on April 22, 2006, 07:15:50 PM
Seriously, there's not too much damage that you could've caused by simply getting a little bit of frozen liquid on stuff. Granted i'm pressuming that you realized what you did immediately and stopped. Also try doing a repair install from the windows 2000 disc. That should replace any missing or corrupt files without overwritting any settings.
Post by: Haystack on April 22, 2006, 08:34:30 PM
Yeah try a repair. You could always just reinstall it over itself. Unless that is what a real repair is. I dunno.
Post by: Ifixyawata on April 23, 2006, 12:04:44 AM
Like I said, I haven't even been able to get the Windows installer fully loaded yet.  It hangs right at the "Loading Windows 2000" part. I did start the regular Win2k install while the version I have installed is "Server".  I can't see how this would make a difference, but again, it might be worth a try. (The CD I have  has w variations of Win2k on it).
Post by: CougarSE on April 23, 2006, 02:17:31 AM
Brian, the problems you are describing sound like a power supply issue.  Now that you have the machine up and running, try a known good power supply.  Not one that just powers up but one that you know will run a computer for hours without a hickup.
Post by: Ifixyawata on April 23, 2006, 01:33:07 PM
I only have one other power supply that has the extra power cord neccessarry to run the newer P4/Athlon boards.  I'm not sure of it's condition, but it powers the computer up but still produces the exact same results.
I give up.  I'll just buy new everything.
Post by: Ifixyawata on April 23, 2006, 07:52:23 PM
Ok, $80 and a new power supply later and I'm no further ahead.  It still hangs no matter what I do.
I even bought a tester for the PS and they all 3 check out good.
What now, new mobo? CPU?  This is getting essssspensive, Lucy!
Post by: Haystack on April 24, 2006, 04:53:00 AM
sounds more like a bad hard drive or something like that to me. Try a format on the hard drive on  diffrent computer. Also, ditch everything. Such as agp video card if it has a built in one,ect. I am still betting on a bad sector of the hard drive. if you have another hard drive you can just throw in try that.
IF it isnt that, I am not sure really.
Post by: Ifixyawata on April 24, 2006, 08:07:59 AM
I can't ditch the video card because it has a PCI-e style and no other ports that I could put a vid card in.
If I get adventurous I might swap in an entirely separate mobo and see if it will boot with that.  If so, that narrows it down to CPU or mobo, I think.
Post by: Funky Cricket on April 24, 2006, 09:46:39 AM
exactly what i was going to say, sounds like the chip or mb got staticked. ( i made that word up, its a good one) try a different chip on the mb or try that chip ina good mb if one is available.
it may also be heat? did the heat sink pull away from the cpu when it cooled ot fast, maybe warped it? might be something to check. also, most parts if under a year old should still be under warrenty.
Post by: Ifixyawata on April 25, 2006, 03:07:46 AM
Well, it must've been the mobo or the CPU, or maybe even the RAM.  I reassembled the computer with my old mobo and CPU (now 1.5 GHz as opposed to a 1.8, Athlon vs. Sempr0n, and 256 ram vs. 1gig)  So it's not too bad of a downgrade, at least until I have money for a new mobo/CPU combo.  The piece runs great, for now... once I have the time (finals are coming up) I'll probably give it another go, but for now this setup works.
Thanks for all your advice, guys.  I might ressurrect this thread once I have the cash for new parts (buying the new PS set me back more than I could really afford.)
Post by: CougarSE on April 26, 2006, 12:20:54 PM
Man i must be lucky.  I've not had to do anything to the hardware in my computer.  Been truckin for 4 years with the old amd 2100+
