Technical => Engine Tech => Topic started by: kingcars on April 18, 2006, 08:02:57 PM
Title: 88 Tbird regular 5.0 questions
Post by: kingcars on April 18, 2006, 08:02:57 PM
My dad and I are checking out the 5.0 HO conversion site (http://www.coolcats.net/tech/advanced/ho_conversion.html) and it mentioned getting a stock HO camshaft, which is a roller cam.  We were wondering if the camshaft in the regular stock 5.0 is a roller cam too because if it isnt, we may need fingers to hold the lifters on.  Also, does the stock block have the bosses to bolt the fingers to?  Thanks for your time.
Post by: Thunder Chicken on April 18, 2006, 10:26:02 PM
I believe all 86 and newer blocks are rollers. 87 and 88 for sure. The Mustang cam will work in your block with your stock lifters, pushrods and rockers
Post by: kingcars on April 18, 2006, 10:34:45 PM
Ok, thanks for the info!  Will we need fingers for the lifters or are they rollers already?
Post by: Thunder Chicken on April 18, 2006, 10:59:41 PM
The lifters are rollers
Post by: kingcars on April 18, 2006, 11:47:12 PM
Ok, great!  Thanks so much.
Post by: Haystack on April 19, 2006, 12:10:42 AM
see if you can get e7's on there too, they will help the new cam breath alot better.
Post by: kingcars on April 19, 2006, 12:14:38 AM
Yeah, we're going to get all the pieces on that list before we do the conversion.  Might as well do it right the first time :) .
Post by: thunderjet302 on April 19, 2006, 12:19:12 AM
Yep 5.0 SO are all roller. Mine is :D
Post by: kingcars on April 19, 2006, 12:50:21 AM
Good, good.  Well, it's time to check the first part off the list of conversion parts cause we just got an HO upper intake on ebay for $5.50 (plus shipping, unfortunately haha).  1 part down...lots to go...
Post by: t-bird85 on April 19, 2006, 02:24:51 PM
Quote from: thunderjet302
Mean 5.0 HO right.....
Post by: Haystack on April 19, 2006, 03:14:57 PM
86-88's were all rollers stock. Everything before that was flat tappet.
Post by: EricCoolCats on April 19, 2006, 03:22:57 PM
Generally...yes. 1985 was the first year for a roller block in a Mustang. All the books list 1986 as the first year for other Fords (Cougar, Thunderbird, Grand Marquis, etc.). But it seems the roller block was a running change for the 1986 model year with the Cougars & T-Birds. I've talked to a couple of people that cracked open their stock early-'86 engines and found they still had solid lifters. I don't think they were all roller until sometime after November 1985. All of my '86 cars have been late builds (March, June) so they definitely had roller blocks.
Post by: thunderjet302 on April 19, 2006, 03:42:42 PM
Yep all late 86-88 Tbird/Cougar 5.0 SO were rollers. There has been fights on panther boards about when Crown Vics/Grand Marquis got roller blocks but the agreement has been late 86 model year and up 5.0 SO were all roller. Now I don't think the 5.0 SO had a double roller timing chain like the HO though but I could be wrong....
Post by: EricCoolCats on April 19, 2006, 03:51:27 PM
You're right---they were single roller timing chains. Also, the 1986 timing chain sprockets were steel, but the 1987-88's were plastic. Yep...plastic. Thanks for the weight savings, Ford! ;)
Post by: Haystack on April 19, 2006, 04:01:53 PM
I would rather be 1 billionth slower in the 18 second second 1/4 mile.
Post by: kingcars on April 19, 2006, 04:51:42 PM
Ooooo, yay, plastic!  Chalk up another thing I'm going to be replacing...  :toilet:
Post by: Thunder Chicken on April 19, 2006, 10:39:46 PM
Eric, I don't think the plastic gears were for weight savings, I think they were for NVH. At least I hope so, because I would hate to think Ford did something like that for weight savings. Not that nylon gears are inherently bad - many of these timing sets have gone well over 200k miles - but the weight savings might net you what, 1 billionth of a second in the quarter?
Post by: 88 XR7 greg on April 20, 2006, 06:28:04 PM
thanks to reading wat you guys just said i'm doing the conversion.
Post by: Innes on April 21, 2006, 01:17:30 PM
Just my advice but if you’re shopping for heads and an intake. Go with the 96-97 1/4 explorer heads they are the exact same as 93 cobra gt-40.and intakes on 96-up are modified gt-40.but only cause you’re replacing them.
Post by: kingcars on April 21, 2006, 09:33:41 PM
Thanks a lot for that info.  I'm on a low budget and the regular H.O. 5.0 stuff is in my price range right now.  I have already bought the H.O. upper intake, but I'll see if I come across that set of heads you recommended.  Also, what does the 1/4 stand for?
@ XR7 Greg - Cool!  Have fun and good luck with your conversion!  :D
Post by: thunderjet302 on April 22, 2006, 01:03:36 AM
The first 1/4 of the 97 model year;)
Post by: kingcars on April 22, 2006, 02:23:30 AM
How can I tell the difference between the first 1/4 of the '97 model heads and the other 3/4?  Is it a part number difference?
Post by: Thunder Chicken on April 22, 2006, 08:46:38 AM
Yes. The later heads are GT40P, the spark plugs are at a different angle than the regular GT40. Supposedly they require a special header, but people in this forum have used regular 50 headers with them, just with a different spark plug boot
Post by: kingcars on April 22, 2006, 10:58:32 AM
Oh I see, thanks :) .
Dad and I took a trip to the junkyard (in the Tbird, of course) to see what 5.0 HO parts they have, but the guy my dad normally talks to wasnt there and it started raining.  Oh well, maybe another day.
