Technical => Engine Tech => Topic started by: 85turbotbird on April 17, 2006, 05:20:51 PM
Title: Gas problems.
Post by: 85turbotbird on April 17, 2006, 05:20:51 PM
How do you know when your sending unit is bad or the float is off? I'm curious because on  Saturday I filled the T-bird up and it was a tad bit above empty and my low fuel light was on, so I filled it up and it only took 10 gallons.  I researched and found that the 83-86 T-birds have 19 gallon gas tanks.  Why would this be happening? Bad gauge or what?!?!
Post by: stuntmannick on April 17, 2006, 10:19:36 PM
This doesn't belong in engine tech, but does the fuel light go off when you fill it up?
Post by: 85turbotbird on April 18, 2006, 12:50:50 AM
Yes.
Post by: 85turbotbird on April 18, 2006, 12:51:30 AM
Was told to do a full tune-up.  Cap/rotor, plugs, wires, air filter, fuel filter, pcv valve.
Post by: 84t-bird on April 18, 2006, 01:04:08 AM
my 84 does the same thing but mine does takes 15 gallons at empty (no bars left on the diggy guage)
Post by: cougrrr302 on April 18, 2006, 01:07:01 AM
Sending unit, maybe. My 84 has buttstuffog and doesnt work anymore.
Post by: stuntmannick on April 18, 2006, 02:54:02 AM
I vote for the voltage regulator on the back of the guage cluster to be going bad.  Where does the needle read when the tank is full?
Also, your float could be the culprit.  Never seen the style of float on these cars, but i'm assuming that it's not foam - so it could be leaking and on its way out.
Post by: 85turbotbird on April 18, 2006, 09:25:18 AM
When it's full, it's a little below F, I believe.  Like, right now I'm on like 120 miles with 1/2 tank!!!!!!
Post by: stuntmannick on April 18, 2006, 02:34:20 PM
Replace the voltage regulator.
There is a write up here (http://"www.turbotbird.com") under the tech articles called "guage fluctuation fix".
Post by: Demented2.3T on April 22, 2006, 11:22:38 PM
another thing to think about is the POS of a tank ford graced is with. Mine is a total POS! if im slightly on an upward slope so the front of the car is slighly higher i cant fill up my car thanks to the huge Flat tank which BTW has  for Baffling to keep fuel at the pump.
Post by: thunderjet302 on April 23, 2006, 12:33:44 PM
Yeah I punched the gas going around a curve with 7 gallons of gas in the tank once. Engine died and came back to life as the fuel slushed around :mad:
