Technical => Engine Tech => Topic started by: Sly1990 on December 07, 2004, 08:35:19 PM
Title: Wanna see a Mini 350ci?
Post by: Sly1990 on December 07, 2004, 08:35:19 PM
Check this Mini 350....
This guys is building funtionnal mini version of V8 engines....
OHV Challenger Block 103CC using Roger Butzen conversion plans, from that I have developed casting of the blower and the heads, valve covers.  the cam is 280 Duration and .105 lift ,lob split 114 deg. .the crank is a one piece 4340 , I machined it to a 90 deg. index and I'm using mike Neal's hall effect system , and firing it using a crank trigger . plug wire are made by mike too. oil pump is a gear drive and I use the stock challenger water pump to keep the engines cool. the blower puts out 6 PSI boost and makes the engine rev very quick . I run them on 114 octane racing gas with lead.  took me 13 months to build 3 engines with the help of my good friend Dwight Giles & body..
(http://www.floridaame.org/GalleryPages/IMG2003/ken%20hurst%20V8%20Engdone.JPG)
(http://www.floridaame.org/GalleryPages/IMG2003/ken%20hurst%20%20v8%20Engdone2.JPG)
Check them running  :
http://www.nvbackflow.com/inprogress/mpegs.htm
Title: Re: Wanna see a Mini 350ci?
Post by: Thunder Chicken on December 07, 2004, 08:58:02 PM
That is probably the coolest thing i have seen in a looooong time. I want one.
The distributor's on the wrong end of the engine to be a Chevy though...
Post by: Bird351 on December 07, 2004, 09:01:06 PM
Wonder what kind of power something that tiny could put out.
Post by: Thunder Chicken on December 07, 2004, 09:08:22 PM
I dunno, but you could make one helluva go kart with it I bet :D
Or a 1/3 scale R/C car...
Post by: Bird351 on December 07, 2004, 09:10:38 PM
Hmmm, a V8-powered go-kart.. it's like a Shelby Cobra, only smaller! :giggle:
Post by: nirvanagod on December 07, 2004, 10:05:46 PM
I call the lawnmower version. That would be freakin' sweet!!!
Post by: slamedcat on December 07, 2004, 10:14:27 PM
I like the Challenger. Flat head v8 with 3 1barrel carbs.
Post by: 88FoxBird on December 09, 2004, 05:04:20 PM
Check this site out. http://www.conleyprecision.com/
